trailer identification |
jcamp72
Groupie Joined: September-24-2012 Location: McDonough, GA Status: Offline Points: 42 |
Posted: January-14-2013 at 3:58pm |
I'm sure somebody has talked about this in the past but couldent find any definite info on it. Can you tell what number and year a trailer is by the id number stamped on the trailer? I'm pretty sure I have a number 3 but wanted to be sure.
Maybe. If its old enough to have a metal ID plate riveted to it, then the model number may be part of the id. I believe my #2 reads 2-xxxx.
The best way to be 100% sure is to post a picture. That along with a few basic dimensions will allow us to tell you which youve got. |
jcamp72
jcamp72
its way big for my 70 cuda probably only have about an inch on outside of bunks.
someone will be able to be more specific but it is a trailer from a mid eighties 2001 model ski nautique.
Ahh, I forgot you were Morfoot's neighbor. I remember seeing that boat when you were considering buying it.
That is a '84-87 #3 delux trailer ('88 was the same but had surge brakes as standard equipment). Its meant for a 2001 Ski Nautique hull, which is just shy of 19'. Yes, it is too big for your 'Cuda, which really needs an older #3, meant for a 17-18' hull. |
jcamp72
TRB
does your #2 have a bow stop like the one in my pictures? |
jcamp72
the reason i asked earlier about the stamped numbers i because the last two are 88 and i figured that was real close to the correct time period.
Are the insides of the fenders open or closed off? 5 or 6 lug wheels?
Close, but not quite... see my post above. I believe brakes were standard in '88, and yours doesnt have them. Ive definitely seen some '87's without brakes. First year for the 2001 delux may have been mid-83, but all trailers were like that starting in '84. I believe CC may have gone from 5-lug 14" rims to 6-lug 15" wheels in '86.
Most of my #2's and #3's are from the '68-80 vintage and have the lower bow stop. Our '79 #4 has the same type of stop as yours. |
jcamp72
so does this one look like a #2 or early #3? |
jcamp72
5 lug wheels and the inside of fenders is closed off.
jcamp72
well i was right about the wheels but i just took a closer look at the fenders and they are open.
That would make your blue trailer somewhere in the 1983.5-1985 range.
That white trailer is a #3 from the late 60's or early 70's... so exactly what you need for your Cuda. |
jcamp72
Awesome thanks for all the help.
Morfoot
Jbear drug the #3 up from Orlando this summer to help him out. Too bad Uncle Todd didn't need a #3 trailer as Lanier is an hour north and Jonathan could get the the boat on its proper trailer.
Ha, Im totally out of the loop on this one... no idea whats going on.
Tim, somebody towed that trailer from somewhere and someone else needs another trailer from somewhere else.
Tim, did I get that right? |
Morfoot
Yes sir you did... Someone is always needing something somewhere, and there is always somebody here that will step up for someone else!
cphase
Gold Member Joined: May-11-2010 Location: Newnan, GA Status: Offline Points: 795 |
Like a prop puller... |
