  New Posts New Posts RSS Feed - New Boat - 1980 Martinique
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 3:55pm
Doc, not sure what is what there, brochure shows as you describe however these photo's of an (presumably) all original 80' that was for sale a while back match what we have.
Tottally agree, our version looks much better.
How kool was the original interior in these, wow. Ours is way past that but the PO did add real teak where the teak stickers were on the dash and some other spots.
Not as much progress this w/e as last but getting close to completing the tear out....What a giant PITA this phase is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 4:10pm
From the Brochure:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 5:50pm
Seems like in 1980 they didn't quite finalize the dash design. We're "lucky" to have the later one.
1982 model year
1983 model year
So half the hull is now missing one to two layers of the original layup.
A "multi tool" was used to score the glass prior to prying it up. Worked very well.
Evidence of hard work
kytom2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kytom2 Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 6:26pm
Looks like a large portion of your budget, was Coor's Light.
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 6:27pm
Well on your way to that first tank of gas.
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 6:31pm
I think you guys actually got lucky with the way that layer is peeling up, sure it's been a while since Quinners seen virgin ground like that.
It's actually looking pretty good, keep at it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 6:33pm
Good progress... and yup, tear out and grinding sucks big time! Based on the color difference and the ease that the first layer of glass is coming up, it sure seems like your boat had an issue with the original layup. Maybe done in 2 stages, maybe a bad batch of resin, who knows. Getting down to that solid pinky color is definitely a good move.
CQ, you look like a natural with that shop vac. Must be all your hoovering experience.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 6:36pm
Your dash is actually good looking as opposed to the other. I do dig that huge wrap around lift up rear seat though!
Those boats have such a classic hull and graphic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 6:43pm
Once we got down to the pink stuff he was lost.
Tim, you can't see it well in these pics but pretty much exactly under the floor level the glass is like a gray color, even up the sides under where the floor lip was. That peeled right off too with a crowbar. Haven't ground anything yet, just cut and peel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 7:22pm
Came up easy, are you friggin kidding me. A hammer and flat bar / crow bar has been the MVP right behind the shop vac, some areas did come up easier then others, the transitions at the bow and stern have been brutal. Dipchit spent 4 hrs Sat cutting down the craddle which I would wager a dollar may prove to have been unnecessary later, lol.
We should also take a pole, saying "I will be there early tomorrow (sat or sun)" what time would you mean, 7am, 8am, noon, midnight, etc.
Waldo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waldo Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 7:37pm
I'll call the hospital and get you guys on the waiting list for the liver transplants you guys are going to need.
Waldo
IAughtNaut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IAughtNaut Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 7:42pm
Anybody else just assume this was implied in any Quinner/Hollywood collaboration?
bring the ruckus
2000 Pro Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 7:49pm
Pole master seems to have forgotten all those weekends last fall that I worked alone while he watched football at the neighbors (but told me he would be ready to work and also refused to answer my calls or texts).
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 7:54pm
I've been somewhat wary of following this thread after the "protruding bump" turned up missing.
nautique frk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautique frk Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 8:33pm
They made a Southwind with the same layout and hull too
Got Tiques View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Got Tiques Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 11:28pm
Some thing about Hollywood yelling "Quinner, You Suck", and it all comes together now.
Seriously, Great work you guys, I'm jealous!! I need to invite you to a '68 Mustang Bump and Grind.
Todd
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2013 at 7:43am
Just read this whole thread...
Wow, nice boat and great progress guys!
And cool (and some funny as hell) pictures too.
I always knew CQ and HW are an inseperable team
AAM196 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2013 at 12:43pm
I used to love seeing those Martiniques, out on the lake... Classy! Seems they've all been replaced with Cobalt I/Os... nice work and nice boat!
I couldn't help but notice the skate board next to a lot of empty beer cases...
Post Options Post Options   Thanks (0) Thanks(0)   Quote kytom2 Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2013 at 12:57pm
Going to use empty beer cans for floatation instead of foam?
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2013 at 1:02am
Any progress as of late?
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2013 at 1:23am
just talked to CQ last night Chris..he sez the boat is tucked back in the corner of the garage. Gonna get back on it this Fall..
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2013 at 1:39am
Figured that was the case but I thought I'd bring the thread back to the top to make him feel guilty
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2018 at 10:55am
Bumpity Bump
We are back at it. In the words of John Winger "I am pacing myself sergeant"
If I can figure out how to post pics I can update this thread
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2018 at 11:59am
5 year hiatus... POIDH
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2018 at 12:45pm
"pictures or it didn't happen."
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2018 at 1:52pm
I have a video that he sent me- what it has to do with boats I haven't figured out yet. Makes Kristof's bathtub picture look Victorian
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2018 at 2:24pm
looks ready for engine drop in
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2018 at 4:35pm
POIDH
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2018 at 4:58pm
I think I would be very wary of opening pictures or videos from CQ...the authorites might be just one step behind.....
But I sure am glad to see this thread back to life. About time we saw this boat and motor back on the water. When did this start...2011?
john
