My 71 Skier Progress |
Post Reply | Page 123 4> |
skicat
Platinum Member Joined: May-18-2006 Location: Duluth, GA Status: Offline Points: 1129 |
Posted: October-24-2006 at 10:01am |
I know a lot of you like pictures, so I thought I would share my progress so far. I'm sure anyone that has jumped into wet sanding the entire boat has questions like is this really worth it? Am I going to have anything to look at when I'm done? When the h*ll will my arms quit hurting? I guess when you get a little closer & can see that shine, it makes it all worth it. I compounded half of the front deck last night & there it was, a bright red boat.
The first two pics are when I brought it home from Indy. The second two are with a newly rebuilt trailer under it getting ready to take over my wifes parking spot in the garage. The third are with the 320 grit sanding done on the hull. The last one is the deck with 1000 grit sanding & one round of compound done. Can't wait till it's done & start on the interior. |
Can't see the pix, I'm sure its very nice; consider using a wet DA, a little soap in the bucket, with 400 then 600, keep the pad wet, keep dunking, the buffing later will then go much faster. With fewer microscratches, the shine will be much more durable.
Randy_in_Ohio
GottaSki- what do you mean "consider using a wet DA"??
I am going to get mine to shine this winter. Maybe replace the pin striping and lettering. I will probably need to wet sand the entire boat also. BTW- How many beers does this project require?? |
Alot- but its worth it. You may not need to wetsand, unless the color is really faded or seriously oxidized. Compound and polish with a good rotary will bring back the shine pretty quick. I wetsanded mine because the deck had yellowed and I wanted to match the bright white that appeared when I removed some original stickers. Id say I spent a good 40 hrs wetsanding and buffing the deck. Skicat, the boat is really taking shape. I love the early Skiers- never seen one in red before. I cant wait to see it shining- keep posting pics! |
Nautique2001
Tim,
A rotary toll won't leave little swirl marks on the gel? Do you put rubbing compound on the rotary attachment? We'll hook up in the spring so I can get all your steps down perfectly. No luck on finding that '88 in NH, Tim. We'll keep our eyes open in case it pops up again. Ken |
re:, wet sanding with a 'D'ual 'A'ction pnumatic sander. Just dunk it in a soapy bucket every minute or so. Soap cuts the surface tension so the surface stays wet.
Whoops, I read the 320 and missed the 1000. I think 320 removes too much gel and leaves too deep a scratches , especially for dark colors. |
Randy_in_Ohio
TRB- Look at that shine!
I am almost certain I will need to wet sand, the boat has quite a few dock scratches and I will need to blend in a coulple dings i am going to repair with gelcoat repair paste. I will have to take some pics and post them... 40 hrs on the deck or the whole boat? Lets do some figuring... 40 hrs @ 3.5 beers per hour... 40*3.5= 140 beers 140/24= 5.83 I am going to need 6 cases of beer! |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5779 |
Skicat,
I wet sanded my 81 last February, Don't worry the soreness will be gone by April. when it's time to ski. It's a lot of work but worth it. Be careful with that 320 it can remove gel real fast. That trailer ended up under Paul's cla$$ic didn't it? Those fenders look familar. |
Ken, the rotary is pretty aggressive- but thats the point. The trick is using progressively finer products to smooth the surface. I wetsanded with 320, 400, 600 and 1000 (2x) grit. I compounded with 3M super duty compound (2x), then microfinishing compound, then Finesse-it II polish (2x). I finished off with glaze and wax, both by hand. Next time Ill probably skip the glaze.
I used specific pads for each product, wool being the most aggressive. Ill have to show you in the spring. Let me know if you catch wind of that '88. Skicat, sorry for the threadjack- looking good! |
Randy, I only did the deck. Luckily, the side gel on my boat doesnt need much work- Ill compound and polish it in the spring, but no wetsanding will be necessary (thank god). I would try wetsanding the areas that need it first and see how they look compared to the surrounding gel. Dont do the whole boat unless it really needs it. Always start with finer grits to determine how aggressive you need to be.
Randy_in_Ohio
TRB Thanks for the good advice... I will get some pics and start a new thread in the near future....
Skicat- keep us updated with photos, I love that red! It's going to look real nice when done. |
we used 1000 then 1500 on a DA, wet sanding the whole time and then buffed with polishing compound and waxed my friends cruiser and it turned out pretty shinny.
skicat
81nautique,
Paul did take the trailer. Don't see many with fenders like that do you! He sent a couple guys down to pick it up for him. I saw the pictures of his boat at the reunion & it looked like he did a pretty good job fixing that one up as well. |
62 wood
skicat, Lookin' good!
I have always wet sand by hand using a rubber block... It helps keep eveything "straight".. One thing I like to use for the water is a spray bottle.. I stole a little one from my daughter (I think she used it for her hair?) Works great for controlling where/how much water you apply.... also, like was mentioned before ... use a little dish soap.. Keep those pics coming! |
skicat
I had a pretty good weekend on the skier. Here are some newer pics of the progress. I have to get the dash, motor box & the bottom yet. Then it's time to get into fixing the gel dings, stripe & wax.
Mojoman
Senior Member Joined: October-31-2005 Location: United States Status: Offline Points: 553 |
Man that looks fanastic Skicat !!! Must feel pretty good !!!
Question for anyone: what's the best product for filling in deep scratches or chips? I've read here anything from Bondo to Gel paste?? I'm going to repaint anyway, so color isn't an issue for me... Hopefully this helps Skicat as well.. Thanks Moj' |
scott8370
Gold Member Joined: November-30-2005 Location: United States Status: Offline Points: 872 |
Also
Gel paste is good. If your going to paint,then Marine Tex would be a good choice, but a little harder to sand.Also,Evercoat makes this purple, fibergla$$ reinforced stuff, that comes in a big toothpaste looking dispenser that actually works great.This stuff would be an even better choice. |
Scott
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6130 |
skicat,
fantastic job...my arms are sore just looking at it. Follow up question to the above discussion. My boat, painted, just off-white, has a few nicks around the rub rail. Anything I can fill those in with when I don't intend to paint again? Any way to match color on patching stuff and polishing out the joints between the patch and the original? Also some gelcoat cracking on the engine cover, not to deep, that I wouldn't mind filling in somehow. |
skicat
I am going to try Minicraft in Florida for my gel paste. There are a lot of threads on here about the repair. I don't know how that would work with paint though. With the gelcoat you can sand it all smooth, but the paint would be a different story. Maybe someone else can help you out with that. Thanks all for the words of encouragement on the boat. All I get around here is grief for taking up the garage!! |
scott8370
If you just want to fill those areas and do nothing else,I would go with a gelcoat patching kit. You can mix this stuff up to make any color. Cost is around $20.00 |
Scott
Skicat, its looking great!
Are you planning on sending Minicraft a chip of your gel so they can custom match it, or are you using a color wheel? Or are you going to match it yourself like Scott mentioned? Id love to have them match it for me, but Im afraid of taking a hole saw to my boat! |
75 Tique
Scott,
How do you smooth that out...blend it into the existing hull paint/fibergla$$? Can't really sand it with paint can you? |
81nautique
Wow, Awesome shine coming back. I love the old solid color boats, kudos to you for putting in the time to restore it and not whipping out the paint gun.
Skicat, I keep coming back and looking at your pics- its really an awesome looking boat. Im curious- what are your plans for the stripe?
Which motor does your boat have, btw? |
scott8370
Smooth it out with a plastic trowel. If you want to patch the paint too, then use that Evercoat stuff for your repairs, then blend in the paint after the repairs are finished. I thought you said you didn't want to paint again. That's why I suggested the gel. |
Scott
bkhallpass
????? I don't believe there were any stripes on a 71. Just solid colors. BKH |
Livin' the Dream
skicat
TRB,BKH,
I have been looking at all of the skiers I can find & the only original looking stripe I see is the one like Reid Pinkham's skier in the diaries section. I am thinking of a stripe like this in white (only the one around the hull, not the deck). The interior will be white with red piping. I think the carpet was the red/black astro turf, so that is what I was considering for the interior. Here is the motor. I haven't seen many of these chryslers. Reids boat |
BKH,
Im referring to the same stripe that Skicat noticed on Reid's boat. You can also see it in the '73 brochure. |
bkhallpass
Got it Tim. I didn't realize it was a skier. I was thinking Ski Nautique. Now I think I'm completely confused. Without respect to authenticity, I think it will look good either way. BKH
Livin' the Dream
I've learned from more experienced gel repair experts, after filling vertical surfaces, apply masking tape right over the new gel to keep it from drooping while it hardens. Working the gel for too long is always regretable.
Wet sand flat with 400 before it fully hardens, then wet 600 after it fully cures. Resist the tempatation to machine buff for a few days. Ambient temperature is critical to good cure, as well as surface prep. |
