  New Posts New Posts RSS Feed - 351 PCM Windsor Rebuild
repip_piper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote repip_piper Quote  Post ReplyReply Direct Link To This Post Topic: 351 PCM Windsor Rebuild
    Posted: April-03-2014 at 1:48am
Hi All, I have a 88 Ski Nautique w/a seized block from over heating. I want to pull it and rebuild the engine. Where do I disconnect it from the transmission? This will be my first engine rebuild.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2014 at 1:53am
Similar to a car,you can remove it from the bell housing or you can leave it on and remove the housing complete
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2014 at 9:53am
I found it's easier to pull the motor and transmission all at the same time just disconnect it at the shaft.
Then once it's out of the boat take it apart then it's a lot easier to get at all the housing bolts.
Smithfamily View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smithfamily Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2014 at 10:29am
+1 Much easier, and I am sure you will want to clean and paint tranny? Bilge?
Js
ny_nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ny_nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2014 at 12:22pm
I agree with removing them both at the same time.
Have some 6x6s or a cradle built to place it on. Then you can remove the tranny and get to work.
- Jeff
1999 Ski Nautique
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2014 at 1:10pm
+2. I don't understand why anyone would leave a transmission in a boat when pulling the engine. It takes half the time to pull it and then again half the time/headache to pull the transmission while it's on the ground/engine hoist.
pholman59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pholman59 Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2014 at 1:24pm
We just unbolted all four engine mounts from the boat at a friends shop who had a big a frame. Disconnected it at the drive shaft. Lifted it out and put it in my truck on a 4x4 frame. It was very easy to measure the rectangular frame the engine mounts bolt to and make the wood frame before hand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ny_nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2014 at 1:27pm
And Vern, if your exhaust headers have rusted bolts, be prepared for this:
The exhaust header thread.
- Jeff
1999 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote pholman59 Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2014 at 6:35pm
Don't let NY scare you. That might happen. But my boat was a salt water for at least 8 years and had seized. My manifolds came right off without any problem. The seized pistons, not so much!
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2014 at 8:06pm
+1 on manifold bolts comment. Whilst repairing a cracked manifold, my bolts came loose pretty easily, and there was no indication that they had ever been off since 1974.
Of course I didn't try the other side...
1974 Southwind 18
1975 Century Mark II
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: April-04-2014 at 6:15am
Yup... Happened to mee three weeks ago. This process involved lots of swearing, busted drill bits and thread tapping as you can see here...
But, we got it fixed. Redneck style nonetheless, because, due to a lack of US thread taps in my uncle's shop, my 351 now has 15 US threaded bolts and 1 metric threaded bolt in it...
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2014 at 1:06am
Ouch grinding next to the truck that can be tough on the paint
Post Options Post Options   Thanks (0) Thanks(0)   Quote repip_piper Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2014 at 7:04pm
Thanks all for the tips. The tranny is in good shape and I was going to leave it in. But if it's easier to take them out at the same time then that's what I'll do (once I locate the driveshaft). Where on the engine do I chain it?
Also a typical car hoist won't reach over the boat. How have you guys hoist the engine & tranny out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2014 at 8:23pm
Paul,
I did some spray painting close to the truck one day and didn't realize the wind direction. Now I have a white speckled finish on the truck hood and left front quarter panel. Thankfully it's a old 95 so it really doesn't matter!
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2014 at 8:31pm
Paul,
A clay bar would take that overspray off pretty easily.
'92 Correctcraft Ski Nautique
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2014 at 9:05pm
Sometimes you have to be creative, if the hoist has the reach then you can take the tires off the trailer to get the height, otherwise you need an A frame or a good tree.
gR@HaM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2014 at 9:16pm
I had major issues with a neighbour two houses down from me for that very reason after redoing the gel on mine. I spent a long time compounding his car and ended up paying for a professional detailer to fix it at my local spray shop. He did a great job, but it turned out my neighbour still wasn't happy, in the end he was being an unreasonable di**head and has since moved house. Thank God
'82 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote repip_piper Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2014 at 12:17am
Just a follow up question. How do I disconnect the Invertaflow fiberglass monster that is above the tranny?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2014 at 3:08am
I loosen the hose clamps and use a large flat head screwdriver to seep rate the hose from the muffler. If you pry it back a little and squirt some soapy water in the space it will eventually act like penetrating lube. It's a fight and sometimes it takes some work to get it loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ny_nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2014 at 9:12am
It really wasn't as close as the picture makes it seem.
- Jeff
1999 Ski Nautique
