  New Posts New Posts RSS Feed - persistent high temp readings
Swatkinz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Topic: persistent high temp readings
    Posted: April-21-2014 at 4:38pm
Have had some scary water temp issues that have been off and on for the past year (or so). Found some air leaks and other issues that have been remedied, but high temp readings persist. Impeller is good. Thermostat is a 160degree and was replaced last summer.
Currently, I can crank the boat on the hose in the yard using the toilet flusher up under the boat. Get the boat to operating temperature and the gauge will read from 180degrees to 210degrees. This is at idle. I've doubted the gauge reading so I purchased an IR thermometer to confirm and what I've found is that when the boat reads b/w the 180 and 210, I can find no spot on the engine or manifold that exceeds 165. The exhaust manifolds too aren't too hot to rest your hands on them even when the gauge reads 210.
I've replaced the temp sender. To check the gauge, I removed the wire from the top of the sender and grounded it out. When doing so, the gauge pegs to the right.
Last summer, during one of these "high readings," I removed the thermostat and it made no difference in the temperature problems.
What next? I was told that a gauge either works or it doesn't. That's about the last thing to check here no?
Any other suggestions?
Steve
2011 Sport/Air 200
Excalibur 343
Former Malibu owner (07, 09)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2014 at 4:43pm
First of all you should be running a 143 thermostat. 160s are for EFI engines.
Second, if the engine is cool then it's simply a read out problem. Could be the sender, wiring or the gauge.
We know that a weak or low voltage ground will cause high readings across the dash. Are the voltage and oil pressure accurate?
bhectus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhectus Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2014 at 5:15pm
+1 on all accounts. My '02 has a gauge issue and it consistently reads around 180. Once in a while it will go just above 180 but then if I tap the gauge it will drop back to 180. Definitely a gauge issue on my boat and I am anal about watching it "just in case". Last year my impeller spun some vanes and I watched it climb up so I headed straight to the dock. I carry a little dime bag of impeller pieces in the helm pocket as a reminder to keep an eye on the temp. One of these days I'll get around to replacing the gauge.
'87 Barefoot - sold
'97 Super Sport Nautique - originally custom built for Walt Meloon
'97 Ski Nautique
'83 SN 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 12:03am
How do I confirm the oil pressure and voltage gauge accuracy?
Steve
2011 Sport/Air 200
Excalibur 343
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 10:56am
What do the gausges read? Voltage is easy to verify with a VOM but it would be nice to know what the gauge reads normally.
Same with the oil pressure. What does it read when cold and then at operating temp? To verify you can remove the sender and screw in a cheap mechanical gauge to see what that says compared to the dash gauge.
When you replaced the temp sender what ohm range did you use?
Eddie
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 11:56am
If the Volts, Temp, and Oil Pressure Gauges (some or all) move noticeably when you honk the horn or turn on your nav lights or even blower, then that's a strong indicator it's a weak ground or weak positive to the dash issue.
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 12:56pm
I want to know where Bret is finding dime bags. I haven't seen one of those in decades...
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhectus Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 1:09pm
LOL. Yeah, since you're farther south and on the coast I'm sure your bags are more like bricks wrapped in duct tape.
'87 Barefoot - sold
'97 Ski Nautique
'83 SN 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 9:29pm
WOW, you are bringing back memories of collage and yes for me that was decades ago!
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 10:17pm
'92 Correctcraft Ski Nautique
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 10:22pm
Keep in mind the horn takes a bit of current to blow, or at least it should. So if the gauges bounce when you honk it I wouldn't be too concerned but if lights etc cause it to dip, check the ground like mentioned before.
dwouncmd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 11:44pm
Collage, that's funny.
Is that what one sees when under the influence of said psychedelic?
89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2014 at 2:10am
a dime bag useta last us all weak....err week. no collage here.
john
psherwin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote psherwin Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2014 at 1:02am
This relates to the temp gauge problem. In the driveway with a "fake lake", yesterday, I was getting the audible alarm and the "Temp" light, but the gauge read no more than 160. Engine was at fast idle with a few "bumps" of the throttle and it just felt "warm". Took her down the road to the lake to adjust and set the packing nut, alarm sounded at crank-up and stayed on 'til I disconnected it. Gauge never showed more than 165 even with 3500+ RPM out on the lake. So sending unit o.k., but warning light and alarm are malfunctioning. What is the remedy?
'86 Martinique,351 PCM
