  New Posts New Posts RSS Feed - 75 Mustang
75 Mustang
jdlang22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdlang22 Quote  Post ReplyReply Direct Link To This Post Topic: 75 Mustang
    Posted: June-20-2014 at 11:45am
Installing a rudder on my CC Mustang. Any one done this before or know something about the installation process. Looks pretty straightforward. I guess I just remove the top pins and then unscrew the big pieces and I guess packing is supposed to go in there?
Skrobo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skrobo Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2014 at 5:12pm
i took mine off & re-installed on my 79 mustang a few months ago. it's as easy as it looks. there should be packing in there, but I don't want to give you false information about what size packing & if you should re-pack it. you may want to catch the rudder from hitting the ground one way or another when you take the bolts out.
MustangMadness View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MustangMadness Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2014 at 1:19am
Just use a jack stand or jack to support the rudder when you undo the packing assembly. You might as well drop the rudder and grease the shaft with a quality marine grease upon reassembly.
I like a 6' beam on a small lake... My Muscleboat
1975 Mustang 225 307RH
