87 Ski Nautique 425hp? |
Post Reply | Page 123> |
scott8370
Gold Member Joined: November-30-2005 Location: United States Status: Offline Points: 872 |
Posted: November-02-2006 at 10:28pm |
Someone claims, they have a 1987 Nautique, with a 454 with 425hp for sale. Was that motor an option?
Scott
Dominique
Newbie Joined: January-19-2006 Location: United States Status: Offline Points: 15 |
In the factory manual for my 454{330hp} , they list a 425hp engine. Carb, heads and cam are some of the differences. Have not seen one personally.
Dominique "Nobody's Business"
ultrahots
Gold Member Joined: September-08-2004 Location: United States Status: Offline Points: 618 |
That one has been on Boattrader for a while.I e Mailed about pictures about a month ago with no response.
bkhallpass
Hey Terry,
How's your restoration coming along? Anxious to see your pics. BKH |
Livin' the Dream
ultrahots
Slow is the word on the 87.Between Baby and Other toys I might find time this winter to finish.Just moved jobs to a Performance type shop.It will be OK to bring the boat in and work on it this winter so I may be the only guy in Wisconsin towing a Nautique in the Snow ! Here is a couple of floor shots before we tore it out.It was broken off of the hull all thru the center.You cannot see the repairs in the Bilge area so I will try to locate those pics as well.
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13520 |
Isn't the python 425 hp? Whoever it is is probably confused it with the 454.
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3365 |
Nope, no confusion. I personaly have footed behind 3 different 80's 2001's with the 425 HP engine, all reside on one lake, there are still 2 there.
It was an 'undocumented' option. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21194 |
GottaSki, do those HO 454's swing LH props?
All the "standard" 330 horse 454's used RH, correct? |
all CC's until late use RH props unless they have switched motors/tranies
Not that I dont believe you Chris, but thats contrary to what Ive heard. Have you seen one of these 425 hp 454's in person? |
I believe so, a factory original '85 I personally had a timing light on, so I was very aware of the direction of the front pully, CW when viewed from the front.
I suspect PCM said you can have the engine any rotation you want, as long as it STD. Observed one in a stars and stripes Mstercraft powerslot, too. The 2001 has better manners at 50 + mph, but can bite you. |
don't confuse engine rotation with prop rotation. when they went to the 1.23:1 tranny all of the engines also went to std rotation fron reverse rotation. But I'm sure you knew that already there didn't you slick. |
Kinda hard to miss since I have a LH motor and RH prop, friend. |
Nautique2001
That's Mr. Slick to you, Chris! |
Ultra, its looking good. Cant wait to see it finished at GL next year.
BTW, I kept looking at the floor seperation pics trying to figure out what the hell was going on. I put the last one right side up and now it makes a lot more sense. Not a pretty sight. Water must have been running right down there, soaking the foam and the stringers. How bad did everything look when you took up the floor? |
Nautique2001
Wow, that's a nasty crack. Did the prior owner warn you about the crack? I would imagine that the boat vibrated like crazy when you took it out.
Ken |
i guess your becoming the resident know it all that doesn't know d*ck about any thing, f**king punk a$$ kids these day's what the hell are you going to do to the motor to increase it from a 330hp to 425hp motor???? first thing I'm going to do is reverse the rotation?????? f**king idiot, bullsh*t jack a$$, you f**kin gind the cam differently, mill the heads, increase the compression douce bag you don't create a completely different line to run it down in the factory. Makes a whole lot a since to create new test stands and all the other bullsh*t for a hand full of motors. |
skicat
Platinum Member Joined: May-18-2006 Location: Duluth, GA Status: Offline Points: 1129 |
We have a winning post! That one from 79 has the most asterisks & dollar signs of any post around!!
I just change my signature and then he goes off in this thread, damn!
kev you need to edit them and loose the brackets and word quote anyway
I just try and keep it fresh for you, kinda like you cann't do it missionary style all of the time with the ladies, you have to flip them over and spank that a$$ no and then. |
Ok I have to remember this thread to come back if I ever get a dry spell of bobchris.
quinner
Chris, I am totally with you on that however for me it is flip my hand over so it feels like somebody else is doin it! |
Chris you need to get a babysitter once in awhile or find a clean whooore that's cheap.
quinner
What about a dirty whooore that's expensive?
Oh wait, that is like a starter marriage. Heck, I think I need one of those romance novels that comes in a brown wrapper? |
scott8370
Hollywood, Perfect timing on the signature change |
Scott
scott8370
Hollywood,
I think my new signature, deserves a little air time.That's a good one! |
Scott
Darrel
Senior Member Joined: June-16-2004 Location: United States Status: Offline Points: 340 |
Theres enuff stuff in this thread alone for everyone on CCF to get a "79" signiture tag line and a cheap clean whooore in change.
Hell we all need a life it's friday night and we're typing away... at least Hollywood is out and about. Well hopefully.
Is it weird that Im kind of proud to be on the receiving end of that spiel? Chris, PCM didnt supply motors to Correct Craft exclusively. I know there are plenty of older MC's with LH PCM's. I wasnt implying that there was a "special" a$$embly line for the few 425 hp motors. It probably used existing HO automotive heads and cam- which may explain the standard rotation. The fact of the matter (at least from GottaSki's experience) is simply that those motors were LH rotation. |
And if they also used a 1.23:1 tranny? then a LH motor right? You realy don't know how the supplier chain works at all.
