  New Posts New Posts RSS Feed - Reverse Rotation toStandard
workky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Topic: Reverse Rotation toStandard
    Posted: October-06-2004 at 5:22pm
Has anyone ever changed there pre 89 correct craft to a conventional rotation engine using a 1.1 trans.What i want to know is how did the boat list and which side did it list to.I know about changing the pump and prop.Just dont know how the hull is going ot react.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2004 at 5:38pm
I talked to Vince at skidim about this earlier this year and he didn't recomend doing it. It does list pretty good and the one person that he know that had reversed the rotation bought a 1.23:1 pcm tranny a year later to counter act the problem, it helped put not as much as needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2004 at 5:43pm
Why do you want to change rotation anyway? There are several places to get reverse rotation parts and complete engines at reseasonable prices? Or are you one of those guys that want to use car parts to blow up your boat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2004 at 9:38pm
.I can get a good deal on a newer pcm engine.And no ,I am not one of those guys who uses automotive type parts on a boat engine.
The parts for a reverse roatation engine are a little more exspensive,it is cheaper for me to buy this "PCM MARINE" standard rotation engine from a friend.I talked to
vince today about it,he said the same thing u did.I also taked with another person who workks for a correct craft dealer that did it to his personal boat,and he had no problems.Other than getting use to the way it pulls in reverse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2004 at 2:13pm
I guess just keep in mind the additional cost of items you will have depending what comes with the block. With a standard long block you will have to use your circ pump, dist, and starter which are not enter changbble from RH to LH rotation plus the new prop and tranny rebuild it all adds up and that's what changed my mind from doing it.
SS 201 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2004 at 4:07pm
The tranny turns either way, just change the direction of the pump, the raw water pump you flip over. All other stuff you chage as previously discussed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2004 at 4:09pm
Im thinking about just rebuilding what i have.Ive figured everything up and the most cost effective way is to just use what i have .I plane on rebuilding the trans this winter anyway.I'm figuring if my blocks ok,ill just rebuild it .
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2004 at 4:36pm
I was told a long time ago that the 1:1 transmission was in the forward gearing, it is geared lower in reverse.
Tim D
882001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 882001 Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2004 at 6:16pm
i was looking at all the same stuff and even switching over to chevy but couldnt beat the deal on having mine rebuilt. 1600.00. i didnt even have a rebuildable block or crank. wish i had of rebuilt the tranny when it was out. there is nothing wrong with it just wish i had piece of mind. and i am going to rebuild all the componets{ alt, starter,carb} as i have money. here is the cheapest internet motor i found.
http://www.ford-motors-engines.com/ford-marine-engine-837.html?engine=FORD%20Marine
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2004 at 10:33pm
Acually im going to rebuild mine myself.I like the peace of mind knowing what kind of components are in my engine.Plus im going to get some gt-40p heads ,and a cam from comp cams.
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2004 at 3:10am
What is special about a GT-40p head and are they available for a Ford 289?
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2004 at 7:15pm
The gt-40p head was made (dont quote me)for the 302 exployers.I picked up a set 2 years ago for my other nautique.I got mine from a ford motorsports dealer here locally.I paid 452.00 for the set,brand new,completely assembled.Im not a big ford fan ,so i dont know if they fit on a 289.I'm more knowlegable with the chevy's.I know on the 351 you have to drill the bolt holes bigger on them.On the 302 they bolt right up,dont know about a 289.Sorry
Post Options Post Options   Thanks (0) Thanks(0)   Quote 882001 Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2004 at 10:43pm
p is for passenger car. for suvs. they probably breathe good.
captan1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captan1 Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2004 at 2:54am
Referring to the tranny direction change, I did it to one of my 71c transmissions and like SS 201 said all you do is turn the front oil pump 180 degrees on the outside of the tranny then you can run it the opposite direction. It's kind of weird because of the sound reverse makes but it works fine. Read this in the manual.
tstafford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tstafford Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2004 at 10:58pm
Stupid question.
Why are marine engines reverse rotation?
Trevor 1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 882001 Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2004 at 11:11pm
nautiques are the only single engine company that i know of that do this. on a twin engine they usually have a standard and a reverse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2004 at 8:19am
CC has not used reverse engines since the 1.23 underdrive tranny
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2004 at 8:21am
Sorry,
Some barefoot did with 454.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2004 at 12:04pm
Just be sure that the crank is ground in the correct direction, othewise you will have problems, you will need the correct crank seals as well. The seals have directional vanes and if you use the wrong ones it will leak. Also comp cams does have a mild cam upgrade from the stock cam profile. It isn't an off the self item though, but does add a lot of HP.
also you will have to re-jet the carb or get a bigger carb if you want to get the most out of the cam and head upgrade.
