  New Posts New Posts RSS Feed - Fuel gauge stoped working
skilime80 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skilime80 Quote  Post ReplyReply Direct Link To This Post Topic: Fuel gauge stoped working
    Posted: September-08-2014 at 4:58am
I checked the gauge and the wires, I think the Float dropped to the bottom of tank, how do I fix it, I hope I don't have to pull the tank!
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2014 at 7:48am
Luckily pulling the tank is a 5 minute job. Take the back divider off, you might be able to see if a wire fell off sending unit without pulling tank as well as take an ohm reading.
leetudor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2014 at 10:19am
Take the positive wire off the sending unit and touch to ground with the key on, if gauge pegs out it is the sending unit.
CrazyCanuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrazyCanuck Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2014 at 9:45pm
You can rebuild the sending unit. I did mine, but my float was okay. It was a broken wire. However you might find a float out there. and then just adjust it. Might be cheaper than replacing the whole unit.
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
