  New Posts New Posts RSS Feed - Flywheel replacement
sandbar53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandbar53 Quote  Post ReplyReply Direct Link To This Post Topic: Flywheel replacement
    Posted: September-21-2014 at 8:35pm
I bought a '91 Nautique Excel. Starter is grinding. I removed the inspection plate and found many teeth missing off the flywheel. Not good! Someone replaced the starter and it was loose. When I tightened it, it helped the grinding but damage was done. Teeth were probably missing before they replaced the starter thinking that was going to fix it. I am going to replace the flywheel myself. Any tips? Open for suggestions.
Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2014 at 8:39pm
No need to replace the whole flywheel,just replace the ring gear, do a search to find out which one to use
Ninety8NeonACR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ninety8NeonACR Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2014 at 8:39pm
I just replaced the ring gear on my 82. Just had to pull the transmission and bell housing. Only cost me $20 and a few hours of my time.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2014 at 2:52pm
Call me if you'd like to order one sir.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2014 at 3:06pm
The V-drive is a little harder, i suspect the engine is what you wish to move instead.
but throw a fresh dampner on while you are at it.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2014 at 4:36pm
I would just yank it all and split it on the floor.
skicat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2014 at 5:25pm
Sounds like a Hollywood quote to me!
Greg
86 BFN
hotboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2014 at 5:28pm
haha where's Don at? He's the only one I can think of that has done this but from what I know pulling the whole unit sounds best. Maybe Jodi can shed some light?
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandbar53 Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2014 at 8:31pm
I want to disassemble as little as possible to get to the flywheel. Also, once I remove the flywheel how do you get the old ring gear off and the new one on? Thanks
Rick
MustangMadness View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MustangMadness Quote  Post ReplyReply Direct Link To This Post Posted: September-25-2014 at 12:16am
Disconnect the prop shaft @ the coupling, the shift cable and coolant hoses to the transmission cooler, and support the engine at the rear so you can remove the Vdrive and the bell housing and then the flywheel. Heat the ring gear with a torch. It should just about fall off before you get it too hot. Heat the new ring gear enough to drop onto the fly wheel. Reverse steps and check shaft alignment.
I like a 6' beam on a small lake... My Muscleboat
1975 Mustang 225 307RH
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandbar53 Quote  Post ReplyReply Direct Link To This Post Posted: September-25-2014 at 5:39pm
Can I remove the V-drive with the bell housing as an assembly, or should I split it? Also, to remove the transmission mount, is it ok to just unbolt the mount from the V-drive? Or should I remove the whole mount?   Thanks
Rick
