  New Posts New Posts RSS Feed - invertaflow muffler
invertaflow muffler
jdalton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdalton Quote  Post ReplyReply Direct Link To This Post Topic: invertaflow muffler
    Posted: November-10-2014 at 11:44am
Looking for a invertaflow muffler for a 1994 correct craft ski nautique... I blew the (fiberglass)side out of mine yesterday... any help would be appreciated...
jdalt
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 11:58am
You can repair it, fairly straightforward.... but I happen to have one that needs a home. It's from a 91 SN.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 12:26pm
Jim,
Steve is absolutely correct that it is repairable. There are several very good threads on the procedure. If you need help, I suggest doing a search for the threads. BTW, I also suggest you finding out the cause of the backfire before you blow another one.
Sorry Steve if you really want to sell the one you have!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 2:14pm
Thanks Pete.... Appreciate you lookin out for me... ha!
As we said, they are easy fixes and expensive to ship (size is awkward).
Use google search to find threads, not the site's search feature
example in the google search box;
site:correctcraftfan.com "muffler repair"
or
site:correctcraftfan.com "invertaflow repair"
Good searching..... and if you are passing through SW Virginia, I have one for ya.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdalton Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 6:00pm
Thanks for the replies..
I may try the repair myself, however, if I am not happy with it, I will be driving through Roanoke around Thanksgiving..
I am fairly new to boating, and I realized after that I did not flip the blower switch before starting the engine (after not running the boat for over 2 months)...
I am no mechanic, but I am assuming this had something to do with it...lesson learned...argh!
jdalt
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 6:09pm
Jim,
The engine backfire blowing the inveraflow had nothing to do with not turning on the bilge blower.
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 6:30pm
'92 Correctcraft Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 6:30pm
Well, I'm in Roanoke and I'll give you a good deal cuz shipping is an issue with something awkward like this....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 6:31pm
Message me if you want to chat more..........
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 6:35pm
Jim,
The backfire may be a sign that the Pro Tech system is failing. Others will come along and comment. They are known to fail. Maybe having a mechanic look at it would be a good idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 6:46pm
I think JPass could address ProTec failure......... He switched his. I'll confirm they are "ticking time bombs" - see my other posts with that same comment but regarding used ones as parts replacement.
ProTec failure is a timing failure... should have performance/starting issues.. Is all good with the engine? You didn't mention backfire....just Pete did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 7:18pm
Mine never failed, but had leaking coil packs. I replaced the ignition before it crapped out on me. I figured 22 years and 1700+ hours of run time was above average life from the ProTec ignition system.
I think you may want to double check your timing when you have some time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 7:27pm
Correct but he did say this:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 7:44pm
Jim, we all seem to want more info... like Paul Harvey - we want "The REST of the Story".....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 9:45pm
[QUOTE=malcolm2] Let's hope this goes well, but I am just about ready to attempt a big time repair of my muffler on my '92 Nautique. This fall a backfire during winterization blew out my muffler.
[Quote]
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2014 at 9:46pm
Reason #10,001 for no mufflers...
LPSL
1974 Southwind 18
1975 Century Mark II
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: November-11-2014 at 10:26am
LPSL
Couldn't have said it better Jeff. Mufflers are just another potential point of failure.
Eddie
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: November-11-2014 at 1:56pm
The look of that style Invertaflow have always bugged me. Seems like a giant wart back there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-11-2014 at 2:40pm
The looks of the Intertaflow is why it's commonly refered to as the "septic tank".
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdalton Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2014 at 12:35pm
My apologies for the delayed response.
Thanks guys for the advice.
Yes, major backfire once I restarted it after parking my truck. Luckily, I was just 10 ft. from the dock, so recovery was easy.
My "septic tank" looks exactly like the posted picture!
The engine is in great shape (351 Ford), so I do not have much to offer on that end.
The only recent repair was to replace the ignition switch.
jdalt
