  New Posts New Posts RSS Feed - Building a house
Building a house
peter1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: January-06-2015 at 8:23pm
you guys in other parts of the country sure do have some weird ideas . concrete without radiant? ductwork in a slab??
the only way through the floor ductwork is less efficient than thru floor is if you have some weird a** ductwork in slab...
as far as 95 + units go it is going to be all you can get soon enough. I love them because I make more $ on parts and i can charge more per hr for my training and knowledge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-06-2015 at 8:25pm
Gary,
The only place I know of is Automatic Appliance in Noridge on Lawrence where you can walk in for parts. You are probably better off on line since I know Automatic isn't cheap.
I don't feel a flame sensor is worth having for a spare. They typically are just a rod in the flame that sends a signal back to the control. On the other hand, a ceramic ignitor (they are shaped like a closed end fork) should be kept as a spare. Grainger has them.
BTW, I've never thought highly of Carrier.
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: January-06-2015 at 9:07pm
YUP... I've seen my share of ductwork poured in the slab, and under the slab for that matter.   Tends to grow mold, sweat, and gets crushed by the concrete... not my favorite Idea, but if Okie is decides to do a forced air system, it can be done well, just takes planning and good engineering... most of our floors are non radiant... just comes with the mild weather we have here.   I like the idea of it though, we have seen more installs in the last few years, but it's relatively uncommon.
not sure I get your question here, but I am curious about what you're asking/saying
Alan - maintenance like cleaning filters/heat exchangers and making sure your condensate pumps/lines are not all gunked up sure helps to make everything work better, that's what I was referring to.   old 80% furnaces just keep on running until they break. put a part or two in and then your good to go again. the basics are the same, but there is more stuff to go wrong on the HE units. Hot surface igniters are a wear item as Joe mentioned.   if one goes out, its a solid 150 for a service call here, plus the part. I'd keep one on hand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: January-06-2015 at 9:19pm
Gary,
2 HWH's in 15 years? Wow, where did you get them? Menards? I'm going on 33 for my A.O. Smith pro max!
I missed this Pete- 1st one was put in by the Plummerr who did the remodel ,think it was a Rhem,second was me,a Sears,cheap units for sure but these days I'd bet they are all the same,nothing is made to last at all although the Bosch seems well built.
john b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john b Quote  Post ReplyReply Direct Link To This Post Posted: January-06-2015 at 9:53pm
I have electric baseboard at the cottage with a thermostat in each room up in the "Great White North" near Pete's place. The place is a small shack at around 1800-2000' with little insulation and single pane windows. I shut the place down around the middle of November but I start it up a few times most winters for a long week end. it draws around 150amps of 220 for quite a while until the place warms up. It is not a cheap heat source, but it is clean and easy. I just signed a contract with WE Energy last month to bring natural gas to the cottage. I expect significant savings. My $0.02 on tankless. If you don't have an almost mineral free water supply don't do it. Pete is right on on this. BTW, my Jotul Oslo wood stove will heat the whole place and saves some $ if you want to deal with it. I have a Heatalator fireplace in the living room as well. It heats the room to very hot but doesn't have an outside air source so it doesn't provide heat like the Jotul. I love a fire so no problem houling wood and ash for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-06-2015 at 10:10pm
My parents home up north was all electric. They both passed in 2004 so that's the last electric bill I know of. It was budgeted at $725.00 per month. 5000 sq. ft. and no AC just heat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john b Quote  Post ReplyReply Direct Link To This Post Posted: January-06-2015 at 10:16pm
Sounds about right, maybe a bit more if I dont burn the Jotul.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: January-06-2015 at 10:20pm
ha ha that made no sense. I was trying to say that there is not much if any difference running duct thru floor or thru ceilings . it all averages out when you factor coolings advantage thru ceiling and heats advantage thru floor.
Okie Boarder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: January-06-2015 at 10:31pm
Have any of you had experience with spray foam insulation on the underside of the roof?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: January-06-2015 at 10:48pm
5000 square feet that huge,I don't add up anywhere near that with 3!
Kris your post about floor ducts brought back a memory from work. We had them there and one year all of a sudden we had water condensating and running down the windows and the walls. The companies maintenance guys came out and found that the ducts had filled with water so they rigged up some pumps and pumped it out. Few days later they are filled again,turns out a water line to the floor mounted washup sink had broke and kept filling them. The companies solution was to turn the thing off rather than fix it-----
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: January-06-2015 at 11:23pm
this concept intrigues me. I checked into it for us and chose against it for several reasons. In fact, I just don't understand the benefits if any. I'm curious as to what others here have to say. One of main arguments is I feel as if I'd be cooling/heating my attic with my house. I want the insulation close to my living space so I'm cooling a lesser area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 12:13am
This is why high/low returns are good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 12:16am
I have not but do know that it creates a hot roof problem. Lot's of debate on the subject but mostly negative. Put the insulation where it should be and that's against the living space and then have plenty of ventilation in the attic. Don't forget a vapor barrier.
SWANY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SWANY Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 12:44am
Plus one, I agree. If you go asphalt shingles it's my believe it shortening the life span of the shingles.
dochockey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dochockey Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 12:55am
Are you putting in a basement ? I assuming your not because your thinking concrete floors ?
where I grew up there are a lot of lake houses on slabs ( the ones right down by the water ). We did several remodels that we cut the concrete to place heat duct runs, not uncommon.
If I was building from scratch and on a slab I would insulate underneath and run radiant floor heat, its clean no blowing dust though out the house. You can run tubing any where like the shower floor and walls, towel bars, the driveway, front walk, etc.
just put down Persian rugs :) plus there is a infinite ways to color concrete.
In the typical home, air conditioning uses more electricity than anything else—16% of total electricity used.
There are ways to save on this and that is Fans, like a whole house fan, consider ac units that just cool particular rooms instead of the whole house.   You mentioned a metal roof they are the best because they reflect more heat where asphalt absorbs and its recyclable.
When I was in china I went to a Sears and walking through the Appliance section it was 2 stories tall and the one wall was just tank-less Water Heaters all the way up to the ceiling !! we are way behind in this field its slowly coming around.
When I remodel My master Bath I'm putting one in but you definitely want to filter the water before the unit.
As for insulating we have done all of the above, and again if I were doing it from scratch I would spray the walls with cellulose,and blown in in the attic and do the most R factor u can afford . Vent the soffits and have a ridge vent.
Stucco for the exterior
and last but not least a 3 car garage with tall ceilings, so you can have a car lift .   My $0.02
1989 Teal Ski Nautique
1967 Mustang
Harris Float
Sunfish
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 1:38am
LOL...why am I not surprised? Same as in Ohio!
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 7:55am
You can not filter out dissolved solids (minerals).
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 7:59am
Besides the asphalt shingle problem, the high heat of a non ventilated roof also degrades the roof decking but also, why heat/cool an unoccupied space?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 8:18am
Spray insulation is expensive especially poly foam. I investigated it when I built my shop up north. I ended up with 2x6 walls with standard fiberglass batts and insulating board sheathing resulting in a R-28. Then the attic was blown with 18" of glass resulting in a R-66. The concrete floor with hydronic was insulated with foam below as well as it's perimeter (important) resulting in a R-20. The shop is twice the size of my little cabin and the heating cost is 25% of the house. Calculating the spray foam cost VS: 2x6 walls resulted in a ROI of 21 years!! Spray foam is only beneficial when you have limited space (cavity) typically on existing construction or money to potentially waist!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 9:48am
y'all are way over engineering this. I have a 2200 living sq ft house with a well and lift pump on septic and my insulation is so thin my joist sit higher.... And last month my power bill was $97 tax, tag and title. I was gonna reinsulate but at that rate, why?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 9:59am
Todd,
Your living in Florida sure helps!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 2:16pm
I'm already considering the foam in the walls, but a subcontractor we work with, for work, told me about a friend that had the inside of the roof foamed, with no insulation in the ceiling. It was a retrofit job along with changing his ducting system from the floor (which was rotted out) to the attic. They foamed the underside of the roof, and removed the standard attic insulation. I'm not sure what they did as far as venting is concerned, but it sounded like it is working well. He mentioned that the attic temperature was in the 80 degree range on a 100 degree day, versus it being 120 on 100 degree day. Interesting thought and I could see how it might be a feasible idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 2:42pm
Andy,
It sure sounds like he is air conditioning his attic now! Duct work can be insulated and preferred in a unconditioned space. Did his electric bill go up? ROI? Roof damage will not show up immediately after insulating the bottom of the roof deck. How long ago did he do it? BTW, I have insulated ducting in my attic and it's 0 degrees out now and dropping!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 4:05pm
Yeah, it seems odd to me, but intriguing. I'd like to find out more about how they do it and what the long term results are like. He only did it a couple years ago, so the long term aspects are unknown with him. From what the guy was explaining, it sounds like his energy bills dropped by about 30%.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2015 at 4:37pm
I have to kiss petes butt here and agree with everything he said.......god that hurt.
in New england the only time i have seen any foam under roof in attic is on very old homes id stick with good venting and insulate attic floor . by the way blown on the attic floor may be better r value than pink stuff but it sure makes any kind of future construction or any chance of using the attic for storage or maintenence a complete mess..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2015 at 10:14am
Has anyone had experience with soapstone counters tops?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2015 at 10:17am
They are very porous,must be sealed and the sealer must be maintained.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2015 at 10:24am
A lot like granite, then?
We've also been looking at the concrete counter tops and they do some great designs with those. Obviously, some of these items may be scaled back once we start talking price. For now, we're considering what all we want and once the design is reviewed and priced, we'll start chipping away at nice to have's in favor of need to have's...lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2015 at 10:29am
its nothing like granite its more like slate in that it is as Pete said very porous. you may have seen old farm house sinks that are a grey black stone   that is soapstone.. i bet you will do a lot of chipping off the list when you find out all the expense of even a basic new construction. its unimagineable what things cost these days.. but always build with the basics if you have to but try and make the future upgrades easily doable later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2015 at 10:34am
Quote but always build with the basics if you have to but try and make the future upgrades easily doable later.
That's exactly one of the key things we are keeping in mind. For example, we'll spend money on building quality that helps for a better house and more efficient. Also, we're thinking cabinets is a key area to spend a little more and get exactly what we want. Countertops may be done in the budget realm now so they can be swapped out later.
Both contractors we're working with are willing to let us do some work ourselves to help on cost. We're also planning to have my father-in-law build our cabinets for us (although, not sure that will end up saving any cost).
