  New Posts New Posts RSS Feed - Recirculating Pump
Recirculating Pump
Mark Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark Mel Quote  Post ReplyReply Direct Link To This Post Topic: Recirculating Pump
    Posted: November-29-2006 at 2:38pm
When looking over my engine (351w) during winterizing, I noticed the pulley on the recirc pump(I a$$ume it was the recirc pump, it's the middle pulley) had some side to side play in it. Felt like the shaft not the pulley itself.
Is this something I should be worried about? I have no leaks from that area.
1978 Nautique
FBook - www.facebook.com/charliedontsurfct
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark Mel Quote  Post ReplyReply Direct Link To This Post Posted: December-01-2006 at 9:49am
Anyone?
1978 Nautique
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-01-2006 at 9:57am
Mark,
Last run out this fall I noticed the infamous Ford Water pump rattle. I found a little side play but no water leaking yet. I think it's a matter of time so I'm going to replace it before hitting the water in spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark Mel Quote  Post ReplyReply Direct Link To This Post Posted: December-01-2006 at 11:44am
Thanks Alan. I'll prob look at replacing it also.
1978 Nautique
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2006 at 10:01am
Mark Mel,be careful when you buy a new pump,the catalogs will show two types of ciculating pumps,one will say bi-directional,the other says CCW, and a large price difference.The true CCW is what you need,and install new belt with just enough tension that the belt dont squeel,too much tension will kill the waterpunp bearing in short order.............boat dr
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2006 at 10:33am
Boat doc,    figured out problem, when they welded the case the heat caused the inner race to move forward in the bore. knocked it back down and it was good to go
        eric
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2006 at 11:08am
Mark,
If I remember right you got your 540 from Skidim, Vince will have the pump you need too.
SS-201 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS-201 Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2006 at 6:01am
They make a newer pump for Ford RH engines, Ski-dim sells them.
SS 201
