  New Posts New Posts RSS Feed - Ignition System
Ignition System
73SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73SN Quote  Post ReplyReply Direct Link To This Post Topic: Ignition System
    Posted: June-08-2015 at 5:55pm
I'm getting real close to finishing assembly on my 351. I'm waiting on parts; I'm hoping to get it back in the boat this weekend or at least next week.
I've been reading up on the distributor, coil, and ballast resistor and I need a bit of clarification.
I've got an electronic ignition distributor and the ballast resistor was bypassed initially.
The old coil got tossed. I have another one but it clearly states on the outside: USE WITH EXTERNAL RESISTOR.
Which is dependent on the BR, the coil or the distributor?
The contacts inside old cap are a bit corroded but everything seems tight. I don't mind buying new if it'll help the engine start the first time and run better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2015 at 6:29pm
either or both -
don't use a coil that needs an external resistor without an external resistor.
73SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73SN Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2015 at 6:33pm
Alright, I'll look around and see what's available. Thanks
73SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73SN Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2015 at 12:52am
This one is $49 plus $11 to ship:
SKIDIM PCM COIL
Summit Racing has the MSD Blaster 8222 for about $54 shipped.
I'm leaning towards the PCM simply because it says "Coil EI" and Prestolite (which is the type I have).
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2015 at 12:15pm
That looks like a good choice to me. Are you working with a 2 wire or 3 wire dizzy?
73SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73SN Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2015 at 2:06am
2 wire: one purple + one black -.
john_33612 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john_33612 Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2015 at 9:46am
this one will not overheat , comes with new resistor and mount     http://performanceparts.com/part/Mallory/29440
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2015 at 10:12am
Then I believe the coil you posted, the one designed to run without a resister, is the correct one. You may wish to call Skidim on the phone just to confirm.
The reason I asked about number of wires, is because the 3 wire Mallory Electronic distributors actually need the coil to be run through a ballast resistor.
Sleepyone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sleepyone Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2015 at 11:06am
I replaced the whole thing on the 87 Nautique with the 454 with a Davis Unified ignition Marine HEI. Very hot spark and no trouble at all. This would be my prefered choise again as well.
73SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73SN Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2015 at 11:23am
Skidim said mine's the original Prestolite conversion with the purple and black and it should work fine.
We'll be boating soon...
