Swedish Ski Nautique 1969 |
Post Reply | Page <12 |
I would carefully stone it to remove anything riding higher than the surface then I would run it and forget about it. Use a couple pieces of hose over. Those rod bolts to prevent doing it again on the other ones. I use relatively long hoses to help guide the rod.
axelg89
Newbie Joined: February-22-2015 Location: Sweden Status: Offline Points: 14 |
Hello all,
Sorry for beeing absent for so long. Have had a lot to do and had my hands full getting the boat ready for the summer and as everything has been going smooth I've havn't had any specific questions. So I followed Joe's advice and put the engine back together being very careful to do everything by the book. I then went on fixing the interor with a new seats, some beer holders, a good stereo and so on. Last weekend I could take it to the lake and fire it up in water for the very first time. So far everything seems to work perfectly which is great. I even did some wakeboarding behind it without any trouble at all Finally I've installed a tow hitch to my car so the '69s can travel in style :) . Does anyone know how much a 69' barracuda with a 351 weights? Now on to a few pics: Engine back together Engine back in place with accessories Put a new gascap on the boat, the small details that matter In water! That great feeling The tow car got hitched! Hope you're all having a great summer! Axel |
Chevy350
Gold Member Joined: June-24-2013 Location: Illinois Status: Offline Points: 721 |
Glad to see your having a blast with your boat! I love the Vette also!
1972 Mustang
shierh
you will have to get the crank machined and get new bearings for it..
Wow you boat has glass stringer and no core, that makes the job easier. |
He didn't have to, and he won't it is perfectly acceptable to use an appropriate stone in that situation to debur and go on with life. It will have no negative effect what so ever on that bearing life. |
ultrahots
Gold Member Joined: September-08-2004 Location: United States Status: Offline Points: 618 |
Joe is absolutely correct. I have seen several a lot worse than this done in exactly the way he described. Glad to see you are out having fun with It !
shierh
i replied on this not seeing second page so missed that he had already done it.
Didnt know that cc used glass no core stringers on some older models. wonder y they started using a core? My 1967 hatteras had glass stringers, no wood and not core in hull. built like a tank and thats y she is still riding proud at 48 years old. |
They didn't,that was a job done by a PO. CC did not start to use glass stringers until most 93 models
As Gary stated, CC didn't back then. The stringer replacement is discussed in the thread. It's interesting use of pultruded glass structural members. |
BuffaloBFN
Super nice all around!
Beware those wrenches on the dash; sore toes, scratched gel coat... |
74Wind
A Vette...Stars & Stripes on the wall...if it weren't for the license plate it looks like an American garage. .
1974 Southwind 18
1975 Century Mark II |
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2879 |
+1 Nice job on the rebuild. Nice garage too. Still.....it pains me to see a hitch on a vintage Corvette. Good entry for the "Show Us Your Tow Vehicle" thread. |
terminaldegree
Groupie Joined: October-05-2014 Location: Georgia, USA Status: Offline Points: 90 |
Good work, Axel!
1996 Sport Nautique GT40/Acme 422
KRoundy
Very cool. Congratulations!
axelg89
Hey everyone!
So last season was a bust due to transmission slipping and despite flushing it and changing fluid it wouldn't get better. During the winter I rebuilt the entire transmission changing clutch discs, bearings and gaskets and installet the trans back into the boat. Test drove the trans this weekend and the problem somehow remained exactly the same which is extreamly strange considering all my work on it. Symptoms include: - Transmission slipping when warm - Oil cooler lines hot on one side but completely cold on the other side. Entire outside of the cooler is sea cool. - Trans case gets hot quickly. As it's the only thing I havn't checked I'm starting to think that the trans cooler/lines are blocked/not flowing enough, anyone had that problem? Any other thoughts? Eveything in the tranmission looked good, I cleaned everything etc. I will take the cooler out and check that it's not blocked and I guess that the next step after is to monitor the transmission oil pressure which I'll try to do next weekend. Does anyone here know what threads/size the main pressure line tap is so I can get the correct adapter/gauge? Thanks / Axel |
Axel,
You didn't mention if you checked out the pump. If worn and out of spec, it won't develop the needed pressure to apply pressure to the clutch pack and keeping them from slipping. Unfortunately, pump specs/clearances aren't published. I don't feel it's a cooling problem since the cooler is doing it's job - hot in cold out. |
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3340 |
Best to put a pressure gauge in the NPT pipe port and see what it says.
think its NPT 1/4" pipe, if not 1/8" pipe, have both. There is a port each for pump, fwd and rev, and they are not all the same size. I leave a gauge on mine all the time. If the pressure is high, could be an indicator of restricted flow. Low, could be bad pump. The best picture would be to sample all conditions. |
axelg89
Well I didn't change the pump which was maybe my mistake then. Insspected it visually and it looked clean from scratches, burs or chips and felt tight in the pump housing.
Is it common that the pump decays? I'll hook up a pressure gauge and check the pressures! |
Yes, a 47 year old pump is always suspect. Best check the pressures.
axelg89
Can anyone tell me if mechanical pressure gauges are the same for air and fluids. Found this in my local hardware store at a good price but it's in the compressed air section... does it matter?
http://www.jula.se/catalog/verktyg-och-maskiner/tryckluft/kompressortillbehor/tryckluftsbehandling/manometer-018028/ BR Axel |
