  New Posts New Posts RSS Feed - rear trans seal help
Lostinattica View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lostinattica Quote  Post ReplyReply Direct Link To This Post Topic: rear trans seal help
    Posted: July-21-2015 at 8:33pm
Does anyone know a special trick to removing the 1- 1/2" trans coulper nut to get to the rear main seal without pulling the trans? Its in an "86 PCM 351 commander? I had to split my shaft coupler and trans coupler with an old punch and hammer, so I am guessing my alignment job was good (Thanks to all on the site that walked me through that job!!). The problem is the 1-1/2" nut inside the trans coupler.. I can't figure out a way to grip or bind it`to loosen the nut to remove the coupler., so I can then change the seal....
The reason I am changing it is because somehow, one of my speaker wires came free and wrapped up on my drive shaft and worked its way to the rear seal, worked under it and bled out all my fluids. By the time I noticed, it was too late to pull out the wire...The seal is shot, or seems shot and must be replaced. Does anyone know the easiest method for removal? . And can I even go about it this way? I mean I feel like i am on the right path but you never know.... My engine rotation is clockwise or to the right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2015 at 8:57pm
50/50 acetone and ATF first then try an impact wrench with a chain or strap wrench on the hub.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2015 at 12:43am
+1 ^^.    Go with the impact and I don't remember having to hold coupler with anything......the nut just spun off and the coupler slid out the back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lostinattica Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2015 at 1:09pm
Ok, I got it off. The impact worked and I took a piece of flat bar with a hole drilled in it and bolted it to the housing to keep it steady. Question. #2, the seal. Do I have to buy direct or will an after market seal work? I found one through the local parts store that's an exact match but only $15 vs. $65 through CC. Any help or advise will be appreciated.
shierh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shierh Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2015 at 2:29pm
is there a groove in the coupler where old seal was riding? if so it needs speedy sleeve or hone the surfact to remove the groove.
I got mine off either amazon or ebay.   got entire trans overhaul seal kit for about what you are pricing the seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2015 at 7:41pm
Ken,
Find the # stamped on the seal and any power transmission distributor will be able to get it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lostinattica Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2015 at 9:53am
Man, you guys are great!!! I got the seal for $2.88 from an auto parts distributor compared to $65 though CC. Can't believe the mark up, but it shouldn't surprise me by now.
So I've got everything back together and changed my cutlas bearing out while I had the shaft removed...I also went ahead and repacked my shaft and rudder. My boat has never run this flawless and quiet. So glad I got it done before the wkend. Thanks guys.
Attached is a pic of the seal in case anyone needs one.it will save you over $60
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2015 at 7:29pm
Ken,
I sure hope that price of $65 didn't come from Zach!
1980nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1980nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2015 at 7:51pm
$65 sounds like the price for the complete Velvet Drive Reseal Kit!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lostinattica Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2015 at 11:12am
NOT a seal kit, just one rear seal and it was $62.38
SEAL, REAR FLANGE (40-A) - 1.23:1 POWER PLUS TRANSMISSION, PCM # R047191
Item Number     R047191
Price     $62.38
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lostinattica Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2015 at 11:13am
http://www.nautiqueparts.com/sealrearflange40-a-1231powerplustransmission.aspx
is the website
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2015 at 7:32pm
Item Number     R047191
Price     $62.38
At those mark ups, White Lake had better serve steak at next years get together!!
