  New Posts New Posts RSS Feed - Temp. guage
Temp. guage
aw380 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aw380 Quote  Post ReplyReply Direct Link To This Post Topic: Temp. guage
    Posted: September-08-2015 at 5:14pm
I have a late 60s Mustang with a 318 CID engine. The temp. gauge does not register and it runs great but very cool. Do these typically use thermostats?
The temp. sender has a wire that runs to another sender in the bottom of the s/board water manifold. What is that sender?
aw380
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2015 at 5:19pm
It's a 50 year old boat, nobody knows what is going on with your engine. Post pictures.
Post Options Post Options   Thanks (1) Thanks(1)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2015 at 6:09pm
Yes, thermostat. If you don't have one, install one. That might explain the cold temperature and with any luck, your low-reading gauge.
Chryslers used 2 temp senders, they are wired such that the gauge reads the higher of the 2. One is on the intake manifold, the other the exhaust manifold. Sounds like your set up is correct.
Pictures never hurt!
