  New Posts New Posts RSS Feed - Sanding/buffing project
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Topic: Sanding/buffing project
    Posted: July-01-2013 at 5:13pm
It's about time I'd do something about the appearance of my boat. New upholstery, trailer restoration, new cover are on the wishlist but they'll have to wait. New board racks are on the way.
The hull is heavily oxidized so that's going to be the first project. I had a little leftover Rubbing compound that I applied on the transom (looked worst). It cleaned it up tremendously, but it still doesn't shine so I think wet sanding is the way to go.
Anyway, someone can bring back some stuff from the States for me now so I'm looking to get the materials for wet sanding and buffing etc.
Can someone confirm that these are the right items:
Super Duty Rubbing Compound
Perfect it II Rubbing Compound
Finesse it II
Wax
A rubber sanding block will be helpful, right?
I can get dry/wet sanding paper locally and think I should be able to find the pads around here too.
Any tips and comments are welcome!
bhectus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhectus Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 5:35pm
Those are the right items! You should be in good shape with that list. And yes, the rubber sanding block will be a good item to have as well.
'87 Barefoot - sold
'97 Super Sport Nautique - originally custom built for Walt Meloon
'97 Ski Nautique
'83 SN 2001
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 5:50pm
Thanks! Would be a pain in the behind if I'd order the wrong stuff. Placing the order right away!
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2013 at 10:41am
I stick with the same line, all Perfect It and start with Super Duty Rubbing Compound on a wool pad. Since shipping may be an issue, pint bottles of everything would be plenty, but get a quart of the Super Duty Rubbing Compound. I use all 3M pads, they're color matched to make it easy. It will shine after the 1st round of compound, and just gets better with each round.   I've also found that if you pic a spot and start sanding with the highest grit you can quickly figure out how far down you'll have to go with the sand paper.
I use the Colonite cleaner wax 920 followed by the Paste wax 885, cleaner goes real fast, 2 uses from a bottle, but has some solvent in it as well as grit so it takes of things that normally require a lot of elbow grease to remove. Paste Wax can lasts forever, I got at least 10 coats out of my 1st can.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2013 at 10:51am
Results!
This is a terrible pic, but in person its hard to tell which way the exhaust tip goes, you can see the reflection even though the pic is grainy.
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2013 at 12:15pm
That looks amazing! Many thanks for your tips.
I ordered the stuff but it's not sure if it'll arrive in time for my friend to bring it back next week. Else a friend of her's is coming and bringing it early August.
In the meantime I can look for the pads and tools.
camprnik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote camprnik Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2013 at 6:01pm
Nice pictures!!
Can you give some more detail in the steps you took? You started with the Super Duty Rubbing Compound then went to the Perfect it?
Also did you do it by hand or use a buffer/random orbital?
thanks!!! and again, awesome looking boat!
Toeboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toeboat Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2013 at 8:31pm
WOW!!! Unbelievable shine.
Toeboat
89 BFN w/454 bought new and still love it.
06 Ski Nautique w/ZR6
72 Promo
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2013 at 3:37pm
The transom was wet sanded starting at 600, it had a sticker on it that didn't get replaced so I had some extra work to get rid of the ghosting. I do 4 steps of polish with the compounding, I'm lazy and the compounding takes out most of the sanding marks. If you're anal about the sanding and truely get it to 1500 then you can skip the compound.
Everything is done with a rotary, actually read the bottle which said 2000 rpms in the past I've gone to 3000, seemed to work just as well, a little slower but easier to hold on to the polisher.   I think most people would be thrilled with just the first step of polish, the next 2 just make the reflection brighter and clearer, but aren't as big an improvement as the first.
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2013 at 4:42pm
Bummed; my friend who brought the 3m-stuff from the US for me discovered when she opened her suitcase that customs took out the bottles because they are "flammable liquids". Boat wax etc for fck'sake. :|
The 'challenges' of living in paradise...
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2014 at 5:30pm
Damn.... it's been more than a year! Now finally picking up this project again.
Like I wrote before customs took out some of the bottles. 2 Made it, but my friend took the labels off that said "inflammable liquid". She didn't bring the labels, so now I'm not quite sure what I have here!
I checked online and it seems that the black bottle is Super Duty Rubbing Compound (3M 05954) and yellow is Perfect it II (05973). However I also saw a black bottle which was (05928) Finesse it II, though in all other pics I saw that was a white bottle.
What do you all say? Looks like I still need to get the Finesse it II.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2014 at 6:09pm
Super duty - black
Finesse it ll - yellow
You should be able to feel the difference between your fingers the SD will be more gritty
oldcuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldcuda Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2014 at 6:21pm
Been a while but my finnesse was always black.
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2014 at 6:40pm
Well those 2 answers aren't going to get you anywhere
Just squirt some in your hand, the finesse is much finer(and whiter) than the super duty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2014 at 8:15pm
Well.....you know what they say...." Once you go black , ya never turn back!"
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2014 at 8:19pm
Thanks guys.
The thing is that I ordered 4 products:
- 05954 Super duty
- 05973 Perfect it II
- 05928 Finesse it II
- and wax.
Only those 2 bottles arrived. So they are 2 of those 3, but which ones, and the 3rd one I'll need to order again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2014 at 8:24pm
Guess when it comes to squirting stuff on your hands we have to listen to Allen. I heard he's an expert with that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2014 at 9:12pm
White stuff nonetheless
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2014 at 9:32pm
I am pretty sure that all the perfect it products are in a purple bottle, the lid is color coded to the pad you are supposed to use, the finess it products are not, so I think you are missing wax and perfect it 2.   I agree that the heavy cut compound was black last time I ordered it. get out your buffer, you are not going to hurt the gel with either product, you should be able to tell which one cuts faster by experimentation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2014 at 11:30pm
I just bought a bottle of 05973,yellow bottle marked 3M rubbing compound
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2014 at 12:06pm
What color is the compound in the bottles? I'll have to check, but I'm pretty sure I have the yellow one (Super Duty)and the compound is white. The colored compounds are in purple bottles and have tops that match the color of the liquid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2014 at 12:15pm
White in mine Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2014 at 12:44pm
I've seen all different colored bottles, can't tell what's in it without the label. Finesse-it II is white and slippery. The compounds are tan and gritty. Super duty is thicker and grittier than all of the 3m intermediate compounds I've used, but I'm not sure you can tell the difference without having seen them both before, or having them side by side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2014 at 1:07pm
My super duty is in a black bottle
Perfect it is purple
Finesse it II clear
I don't know anything about "colored tops" that Don speaks of. All the caps are white
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2014 at 5:04pm
All my purple bottles have a top that matches the color of the compound inside and the foam pad they were designed to work with. I've had them for a few years so they may have changed things, but it's pretty idiot proof.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2014 at 7:32pm
Mine too, and they are about a year old, so I think they haven't changed anything.   Amazon.com would have pictures of each bottle if you want to look for product pictures
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2014 at 8:15pm
Looks like 3M is changing up bottles all the time.
I checked today and the black bottle had more orange colored stuff in it and much grittier than the yellow bottle, which had more off-white/yellow liquid.
Now all I need to get is the Finesse it II, I believe. And the pads. And sanding paper. And some extra time!
On to the next question:
Pulled off the stickers I had on it today. What's the best way to get rid of residue of stickers?
Current status:
Pretty obvious where the stickers were!
Thanks everybody for all your help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2014 at 9:05pm
Acetone or Xylene
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: September-06-2014 at 12:30pm
3M makes a good product in a spray can I picked up at the Autoparts store that works great.. Bug, Tar and Adhesive removal.
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2015 at 3:30pm
LOL 2.5 years later I've finally started cleaning up the hull.
I can't get the 3M products here, so I'm looking for a replacement for the Finesse It. Anyone know what the equivalent from Meguiar's is?
