  New Posts New Posts RSS Feed - 2002 electric activated hatches
t.franscioni View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.franscioni Quote  Post ReplyReply Direct Link To This Post Topic: 2002 electric activated hatches
    Posted: April-26-2016 at 9:54pm
Anyone know what this device is that is inline on the power wire that runs from my fuse box to the left and right replays that activate the latches on my engine cargo hatches?
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.franscioni Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2016 at 9:55pm
sorry relays not replays
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2016 at 10:08pm
What do you mean by electric hatches on your engine cargo hatches? What boat do you have?
1974 Southwind 18
1975 Century Mark II
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2016 at 10:12pm
Looks like a circuit breaker
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.franscioni Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2016 at 10:23pm
74wind, it's a 2002 super sport/super air. The storage compartments on either side of the engine have electric latches activated by push buttons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.franscioni Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2016 at 10:26pm
There's already a dedicated circuit breaker for the electric latches in the fuse box so not sure why there would be another circuit breaker in this power wire to the relays for the latches?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2016 at 10:59pm
Yikes.... ....new boats just continue to boggle the mind.....
1974 Southwind 18
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2016 at 12:04am
Who knows what has been done since '02
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.franscioni Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2016 at 12:51am
Well that sure looks like it... Those style are automatic reset? Or is it like a fuse where's it's one time use and then replace it?
I will trace the latch wiring system further. Could be that circuit breaker in question protects the main power wire that feeds the relays and the "latch" breaker in the fuse box is for the latch actuators themselves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2016 at 7:25am
Well that sure looks like it... Those style are automatic reset? Or is it like a fuse where's it's one time use and then replace it? .
Those breakers are a thermal type which do reset after cooling down.
I feel you will find this to be how it's wired. Yes, the large breaker is for the main power (high amp) to the linier actuator through the up down relay/contactor and the small breaker in the fuse box is for the control circuit (low amp) to the coil in the up/down relay/contactor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.franscioni Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2016 at 11:35am
