  New Posts New Posts RSS Feed - Marine Distributor
Marine Distributor
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Marine Distributor
    Posted: January-28-2020 at 4:55pm
The vacuum advance probably won't work very well. Unlike automotive, the marine engine being under load most of it's RPM range doesn't produce the correct vacuum. You can try it but what's really needed is a distributor with a mechanical advance.
Wilhelm Hertzog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wilhelm Hertzog Quote  Post ReplyReply Direct Link To This Post Posted: January-28-2020 at 4:19pm
Does the auto distributor still have the vacuum advance and is it connected?
Yes, it still has the vacuum advance, but no, it is not connected. Should I connect it? I guess checking whether the ignition advances enough through the rpm range without the vacuum advance is probably the first thing to do before connecting.
Do not go gentle into that good night. Rage, rage against the dying of the light.
rosconole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosconole Quote  Post ReplyReply Direct Link To This Post Posted: December-26-2019 at 1:27am
Are we talking about an Australian distributor ? Don't their toilet flush backwards ?
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-25-2019 at 4:22pm
Originally posted by Wilhelm Hertzog Wilhelm Hertzog wrote:
   PO of my boat installed an automotive distributor that I doubt has been marinized like you did, and I am concerned it is causing some issues with my motor's running.
What are the issues with the engine? Does the auto distributor still have the vacuum advance and is it connected?
Click on the link below and you'll see pictures of his distributor and some of your questions will be answered.............only some of them.
You'll also find the link that took him to this thread in the linked thread
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-25-2019 at 12:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wilhelm Hertzog Quote  Post ReplyReply Direct Link To This Post Posted: December-25-2019 at 11:37am
Originally posted by Nautiquehunter Nautiquehunter wrote:
I will keep you posted as time goes on.
Has this distributor been working fine for you? PO of my boat installed an automotive distributor that I doubt has been marinized like you did, and I am concerned it is causing some issues with my motor's running.
Nautiquehunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2016 at 10:22am
So here is where I am . I bought the dist and 8mm wires . I then removed the vac advance and installed a aluminum bracket to prevent the pick up coil from moving. Then I filled the hole in the base where the vac advance went through. I then drilled 2- 3/8 holes in the bottom of the unit and epoxied fine brass screens to the inside. I installed the dist and wires and checked the timing. The total advance of the original dist was 15 degrees it was the same on the HEI unit so no adjustment was required. Engine starts immediately and runs great . I will keep you posted as time goes on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2016 at 10:06pm
Originally posted by H2oXtremes H2oXtremes wrote:
I have been reading on other Ford forum sites that the oil drive pump shaft can stick to the bottom of the distributor and come off and drop into the oil pan when removing the distributor, has anyone else had any issues with this? I am trying to prepare myself for that nightmare.
Only a problem if someone has had the engine apart and either removed the clip on the oil pump driveshaft or put it in upside down if even possible. More likely that you would have trouble getting the distributor to seat on the driveshaft,but thats not a big deal either just some wiggling and maybe lowering the front of the trailer.
As for searching just use google type in Correct Craft Fan distributor or what ever else you want to look up
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2016 at 8:49pm
Alright it seems I can never get the thread search option to ever really pull up any searches unless I type out exact matching phrases of a topic, I guess keywords isnt something this site can understand So I am sorry in advance is this topic has come up before. .
Use a "google" type search as the sites search feature isn't the best.
H2oXtremes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H2oXtremes Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2016 at 8:13pm
Anyway I am replacing my distributor on my 351w, but I have been reading on other Ford forum sites that the oil drive pump shaft can stick to the bottom of the distributor and come off and drop into the oil pan when removing the distributor, has anyone else had any issues with this? I am trying to prepare myself for that nightmare.
1985 Ski Nautique 2001
Post Options Post Options   Thanks (1) Thanks(1)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2016 at 10:28am
I was hoping to get some facts how does the manufacture of the marine dist make it so?
Its obvious they started with a stock automotive dist and modified it for marine use . Just like with starters,alternators,fuel pumps and carbs all are modified automotive parts modified to be marine compliant. I know the vac advance will have to be removed and the gap filled and sealed to the cap . 3/8 vent holes covered with fine brass screen and reset the advance curve will be needed . Did I miss anything?
That's basically it, part of the process would likely be testing and making fixes based on the results of that testing. I have had a few boxes tested for hazardous locations, sometimes they pass easy sometimes something unexpected causes issues.
I would also be very careful of the quality of the distributor... I doubt you are worrying about a reverse rotation gear for what you have in mind but do pay close attention to the gear.   I just got towed home a few days ago in my truck because I replaced the 38 year old original distributor with a new one from the local autozone cause I figured I would treat the new engine to all new parts.   The new distributor had a clearance fit on the gear, and a cheap excuse for a roll pin to hold it in place.   It made it about 50 miles.   Half a day of work lost and 135 for the tow and I am back to the old distributor and running like a champ.
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2016 at 7:26am
Originally posted by Duane in Indy Duane in Indy wrote:
   I have done several gear swaps It is best done on a milling machine but can be accomplished on a drill press.
Duane,
I feel when accuracy is difficult it's one of the reasons taper pins and reamers were developed waaaay back! Actually, I also feel this is a great application for a taper pin.
Pete, The real problem is that gears are not interchangeable from one dist to the next. They drill them at assy and not the same. Just about have to rotate the gear 90 degrees and re -drill the gear. You want the pin in the initial hole in the shaft so as to not weaken the shaft. Also I hate to disagree with you but I would NEVER use a taper pin on a rotating application. Split pins stay tight. Just my experience
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2016 at 7:06am
Duane,
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2016 at 9:21pm
Well, if you buy one advertised & used for the intended marine function, liability falls on the manufacturer if something goes wrong.
If you convert it yourself & something happens, you are the deep pockets they go after . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2016 at 1:58pm
Just a quick side note FYI:    Dated (1/6/2016)    Yesterday MSD Performance announced that they have officially acquired the ACCEL Performance Group who owns not only ACCEL Ignition, but also Mr. Gasket, Mallory Ignition, Lakewood, Quicktime, and Hays.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2016 at 1:47pm
I would not hesitate on converting one. Might be a little bit of work on the one you found but I searched this one out.
eBay item number:121985933398
Granted, 5 days to go but Summit wants $445 for the same thing.
Easy to switch over. Hardest part is obtaining and installing the RR gear   I have done several gear swaps It is best done on a milling machine but can be accomplished on a drill press. If you need the gear let me know. I have one left over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2016 at 1:17pm
I think you would have to check to see if it even has any mechanical advance at all,some modern ones do not. Some are vacuum retard for emissions too.
The Mallory YL in the older Holman Moody's were automotive ones converted to marine but they started out as a dual point centrifugal advance to begin with. They removed a set of points,made a new point plate and put the condenser inside. No screens were installed either. I filled the vent hole and installed a screen assembly from a junk distributor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2016 at 12:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2016 at 12:15pm
Michael,
Considering the mark up typical of OEM parts, I have a feeling that you would end up spending more than a new marine to convert the automotive. Let's see if anyone else has any ideas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2016 at 12:08pm
I found an HEI distributor for a ford 351w for less than 60.00 the same marine distributor is more like 300.00 . Other than the vacuum advance, venting and advance curve what is the difference between the two. Has anyone marinized a automotive distributor?
