  New Posts New Posts RSS Feed - fake-a-lake
fake-a-lake
tjs1295 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjs1295 Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2016 at 2:43pm
YES!! Thanks Hollywood. I see what you're saying, makes perfect sense. I also see your point bb12. I just like making sure the rwp & impeller are working correctly, and not sucking air.
bb12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bb12 Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2016 at 3:46pm
The bucket method is ultimately best for testing the RWP, but you can get a pretty good idea if your pump is working properly with the T method as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjs1295 Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2016 at 5:19pm
I agree. I will most likely put in a "T". It is pretty slick.
Greg_SA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_SA Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2021 at 3:19am
I guess it matters on how your original installation is. I wanted to keep the strainer level so I cut out a piece.
In this setup, when connected to the hose, doesn't water just pour out of the pickup under the boat?
1989 Ski Nautique (SN2001)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2021 at 8:19am
The "Timmy Tee" works. Yes, you get water out the through hull but the RWP sucks what it needs.
