  New Posts New Posts RSS Feed - TimmyT, Radio, etc INSTALL
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2016 at 4:21pm
Dan,
See if you can get a screw type terminal block before having to use the Noalox. In the long run, I feel it would be a better solution plus, less messy!
Premade jumpers are available.
planejob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote planejob Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2016 at 6:15pm
I'm worried that you are fixing your grounding issue only to introduce another issue that will bite you in a few months. They make marine bus bars, and some guys are artists with wiring.
Check out this guys effort: (stolen from the hull truth)
flyweed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flyweed Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2016 at 6:42pm
you guys talked me into it! Heck, this aluminum bus bar was only $3.00, so since I have to wait for my new push button breakers to arrive, I'll just order up a Marine Grounding block too.
Pete - those bus bar photos you posted above...aren't those "individual circuits" per each two screws? I mean, there is nothing underneath them connecting them all together is there? I mean, that's why they call them "2 circuit" , "4 circuit", "6 circuit" and so on..
Drink Tonight..for tomorrow We Ride!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2016 at 6:59pm
Hi flyweed
Go back and look at Pete's picture of the terminal blocks and the little picture underneath them.
It says "premade jumpers available" and shows one. That's what they're for. You can jumper together as many circuits as you want with them so order a good number of those too.
KenO
Post Options Post Options   Thanks (1) Thanks(1)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2016 at 9:39pm
Originally posted by spiralhelix spiralhelix wrote:
just for testing purposes...disconnect the wires on your blower breaker (or whichever is next to the ig breaker) and move the ig breaker wires to that one and retest.
Dan, while you are waiting for your new breaker, you could do the above to prove out that everything in the dash has proper voltage once you have a known good breaker. I did this to rule out a problem about a month ago, takes a minute and you'll have the answer.
Also ..... just a compliment on being very receptive to advice given here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote flyweed Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2016 at 11:22pm
63 -   I will certainly do the wires over to the "blower" breaker tomorrow and test it out sounds like an easy enough test.
Hey, as far as being receptive...I have owned boats for years now, but this is my first ever Inboard/direct drive..and there are TONS of you guys who know alot more than me, so I am eager to learn as much as I can on maintenance, upkeep and repairs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote flyweed Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2016 at 5:56pm
Ok, how is this "grounding" bus bar?
I picked this up, of ALL places, WAL MART! Stainless Steel, plus a clear cover
Is this a good one?
spiralhelix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2016 at 6:43pm
+1
-Spiral
'89 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2016 at 6:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote flyweed Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2016 at 10:51pm
63 Skier....Ok, I did as you said, after I got my new grounds connected, and the new Hot as well. I connected the terminals from the ignition breaker to the blower breaker and everything was "like new" on my dash..the voltmeter is reading 13 volts, ALL of the lights in the gauges worked, Heck, I tried the horn (which did not work before) and they were a little "squeaky" at first, but loosened up after a few pushes of the horn button, and now they work again. LOL.
So just to confirm that my ignition breaker was the problem, I cleaned it really good with contact cleaner, and a brush, and worked the breaker button a few dozen times. I reconnected the ignition wires back to the old breaker, and sure enough I had 2 volts less on the voltmeter..only reading 11 volts.
So glad, all of this is slowly coming together!
Post Options Post Options   Thanks (1) Thanks(1)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2016 at 11:32pm
Nice to find a simple, easy to fix solution! Doesn't happen all that often.
Have you posted any pictures of your boat anywhere? Curious to see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote flyweed Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2016 at 11:57pm
Oh yeah...you can see TONS of before and after pics of my boat over at this thread:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=39775&PN=1&title=started-buffing-my-93-sn
