getting ready to winterize |
Post Reply | Page <12345> |
Ah, I get it now. I totally agree, drain it all...
Good morning Ken. it's coffee refill time. |
bb12
Senior Member Joined: March-24-2009 Location: Kansas, USA Status: Offline Points: 355 |
Sounds good, thanks Ken and HW.
1989 Ski Nautique 2001
flyweed
Gold Member Joined: July-11-2016 Location: WI Status: Offline Points: 544 |
Ok guys, winterized my 93 today, and have a couple questions.
1. on the raw water strainer...how the HELL do you get the screw off "cup" off and back on? mine did come off with some effort, but it felt like the threads were super sticky, and I can't be sure I got it screwed back on tight enough to seat the rubber O ring. Can I put some grease or something on the plastic threads to make removal and re-installation easier? 2. I unbolted the raw water pump and pulled the back off to inspect the impeller. It looked like new. BUT...I can't remember what way is up and what way is down on the pump to bolt it back onto the engine. Any help would be great. |
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2880 |
I used a bit of petroleum jelly on both sets of threads. Works great. JQ |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10790 |
go to this link and look at Hollywood's post complete with graphics and you'll get it right this link |
flyweed
Thanks..that helps alot.
One other question. I topped off my gas tank, and I thought when the tank got full I'd see gas come out the little chrome "vent" next to the fill port. BUT, when I got full gas would gurgle and spit out the FILL port where I had the gas nozzle insert.... Any thoughts? |
Plugged vent?
flyweed
how do I check the vent..just blow into it? or should I remove seat back, and disconnect vent hose??
spiralhelix
Senior Member Joined: August-06-2014 Location: IL/WI Status: Offline Points: 496 |
Huh, that happened to me every time i fill up, but never seem to have venting issues. I just chalked it up to the fill hose filling quicker than the shutoff can react. I started using the lever release at the lowest setting and when i think im close, finish manually. Plus the fill hose inserts into the tank lower than the vent.
Another explaination is that there should be a "loop" or vertical bend to help prevent water from entering the tank via the vent, and if that bend is above the fill hole, it would be difficult for the gas to breach that bend. |
-Spiral
'89 Sport Nautique |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4251 |
I have to fill carefully too, go slow as it gets full, or it kicks back out the fuel fill.
You really don't want to fill to the point where it flows out your vent. Yes, you definitely want to verify that your vent is working, I guess I'd start by blowing some air in the fill and seeing if you feel air coming out the vent, easier than pulling things apart to look. I asssume you are worried that your tank needs to be full to the brim for winter storage. Lots of differing opinions on this, and do a search and you'll find the comments easily. I'm not a believer in it, just stabilize the gas and leave it, I'd rather be adding fresh gas in the spring to a tank left fairly empty rather than having a full tank of stale old gas to burn off in the spring. Like I said, lots of opinions both ways on this, but I'd say it's the least important of all your winterizing decisions. |
JPASS
Our '92 would overflow if we used the lock on the gas pump handle. Had to fill it slowly to avoid this. Vent worked fine as you could feel air being pushed out as we filled the tank.
'92 Correctcraft Ski Nautique
flyweed
yep, I just confirmed my vent is free as well. I removed gas cap, and blew into it, and air easily came rushing out through the vent. Guess I'll just have to fill slower.
flyweed
petroleum jelly on the thread for the raw water strainer and ALL is well. Went on super easy.
Now, I found something that concerns me. Upon sucking out and changing the transmission fluid. It was pink, but milky pink. I've read enough already to know that water is mixed in there. (with my hand pump, I only managed to suck out about 1 quart). and replaced with fresh. my hand pump was bottoming out, so I assume I need a smaller diameter hose to get down to get more than 1 quart out. Also, my Bilge floor is clean and dry, no water, no oil, no transmission fluid. Can I assume I should order a new Trans. Cooler and replace the old one (that is original-1993) |
spiralhelix
I would flush it a 3-4 times first (running between each flush with water directly going to RWP) and then run it briefly to see if the problem persists before ordering a new cooler. The water post cooler just keeps from reintroducing more water IF the cooler is the problem. I would want to make sure I get all the milk out first so it is definitive the cooler is the problem and not just remixing of the old stuff. Though, this method would get expensive with all the wasted ATF if the cooler ends up being the problem.
-Spiral
Before ordering a new trans cooler, I suggest pressure testing it first. You don't want to become just another one of those "parts changers"! |
Cooler is probably fine. If the bilge has ever been flooded water can enter the transmission. It'll stay there too because it's more dense than ATF.
63 Skier
Yes, seems more likely it just got in through the breather at some point. Or, could be condensation if the oil never was changed, doesn't take much water to milk up the oil.
Do one change, run it, and see what it looks like then. If it looks better I'd just do one additional change and call it good. You can't get all the oil out anyway so may not be pristine looking, but will be ok. |
flyweed
so, since the engine is completely winterized now, do I "un-winterize" it now and start the engine up, and work on this..or drain and change out the transmission again, and let it go until spring?
How does one pressure test the cooler? I don't really have the tools necessary to do a pressure test (I don't think) |
pressure testing isn't always as painful or expensive as one might think... a 5 dollar harbor freight bicycle pump and a couple rubber plugs drilled and filled with lag bolt and hose clamps can often make things happen.
Dan,
Running the engine to circulate the ATF would be a good idea but don't drain the engine.. I'd pull the belt off the RWP and start the engine for about a minute then change the ATF. If you still get pink, do it again. You don't want water sitting in the trans over winter. I didn't mean to scare you about pressure testing the trans cooler! But, as Joe mentioned it's not a major project. I prefer to pressurize the oil side because of the threaded fittings. A trip to the auto supply will get you fixed up with a couple fittings to plug one end and get some compressed air in the other. After you pump it up with air (about 20 PSI) stick it in a bucket of water and look for bubbles. |
I use a 1/8 copper tube to get all the way down to bottom on tranny. There is a small hole that the dipstick goes into, so a normal hose won't fit. Be careful not to drop the tube in there!
Use a long tube than can't drop to the bottom! |
flyweed
here is a pic of after I did the original trans fluid change yesterday. Today, I did as suggest. unhooked the RWP and ran the engine today for 1 minute...then I drained what I had put in yesterday. Here is the photo of what I drained today after the 1 minute run.
Yesterday was yesterday. Today is today.
Fluid looks fine |
quinner
I wish I had tomorrows newspaper
flyweed
LOL..Ok Ok, After re-reading my last post..I realize that was a bit confusing! Anyway, the fluid in the above pic was after running my engine for 1 minute, with no water pump running. should I change it out again, or ????
I'd run it longer than a minute between flushes.
flyweed
should I flush another time and add new fluid..or call it good?
bb12
Is that Bloody Mary mix?
From the picture, it still looks like it has a milky tint to it. I'd run the engine again and do one more ATF change.
