  New Posts New Posts RSS Feed - Airguide Speedometer Conversion to GPS
cphase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cphase Quote  Post ReplyReply Direct Link To This Post Posted: January-28-2013 at 10:20pm
Thanks,
Jeff
82 SN
Arch Linux
ClassicBoatwork View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClassicBoatwork Quote  Post ReplyReply Direct Link To This Post Posted: January-28-2013 at 10:29pm
I don't know how you did it but Thank you... oops.. I see the insert link button up there now!
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: January-28-2013 at 11:43pm
you need the old airguide to do the work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClassicBoatwork Quote  Post ReplyReply Direct Link To This Post Posted: January-28-2013 at 11:56pm
Yes, I will install the unit into your speedometer.
Ahhh, Argentina.. I see. If you wish to take advantage of the special and install yourself that is okay. I can hold off shipping to you and supply an install kit when I get it worked out. Or you can use your current frame and I will walk you through as much as I currently know.
We are all learning together here!
Thanks,
Dean
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: January-29-2013 at 12:14pm
Guessing you can do them for different faces, but how about surface mount units? Sorry if this question was covered earlier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClassicBoatwork Quote  Post ReplyReply Direct Link To This Post Posted: January-29-2013 at 2:24pm
Yes, the conversion should fit any Airguide speedometer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClassicBoatwork Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 3:33am
I have added more information on the GPS conversion:
Here
And Here
We also now have a form for questions and quotes:
Form
turningpoint84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turningpoint84 Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 12:45pm
you link just takes us to this thread.
1970 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClassicBoatwork Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 1:17pm
arg.. I don't understand these links I guess...
http://www.classicboatwork.com/classicparts/gauges/airguide/agr/agr.html
http://www.classicboatwork.com/classicparts/gauges/airguide/gps/gpsretro.html
http://www.classicboatwork.com/form/gpsform.html
Sorry about that... Dean
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 1:59pm
Yeah...still needs a little work
Here you go.
Air Guide Service
Air Guide to GPS info
Inquiry Form
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 2:05pm
Dean, go ahead and quote Larry's post above, you'll see where everything fits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClassicBoatwork Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 2:05pm
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClassicBoatwork Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2013 at 2:13pm
I think I see my errant ways... I added the quotes to my link and your software does that automatically.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClassicBoatwork Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2013 at 9:10pm
I have finished my first pair of GPS retro-fits.
I took the pair out this morning in our car and they track together great.
bhectus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhectus Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2013 at 10:37am
The sweep on the flush-mount only goes to 40mph? I thought it was going to go to at least 47?
'87 Barefoot - sold
'97 Super Sport Nautique - originally custom built for Walt Meloon
'97 Ski Nautique
'83 SN 2001
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2013 at 10:46am
The flush mount pictured is a "fancy" Electro-Speedo....... not a typical flush mount pitot-driven Airguide which has a dial that is calibrated to 50 MPH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2013 at 12:59pm
It looks like the optional electronic speedo from around 1980.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2013 at 2:05pm
HW is right on. Wasn't there a set of those on ebay a few weeks ago?
That GPS is tempting. I would like to fill in all the pitot holes on my transom and never have to worry again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClassicBoatwork Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2013 at 3:00pm
Now that is the right kind of thinking!
Someone told me the Electro Marine was used for only three years. Paddle wheel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClassicBoatwork Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 4:24pm
nautic Laugic did a pretty good video on the installation process.
I cringe when he tells you to cut off the nipple on the diaphragm though!!
I have never seen that plastic frame before.
Video
Dean
Dank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dank Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2013 at 5:04pm
So how much are you selling the DIY kit for?
"I don't know what the world may need, but a V8 engine's a good start for me"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2013 at 9:40pm
My 1980 came with the Electronic Speedo, but I replaced it with an Water Pressure Air Guide. I am thinking that 1980 was the only year that this was offered .
Very Cool Stuff.
Donald
Wet-N-Frugal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wet-N-Frugal Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 9:37pm
More info on the GPS upgrade:
You can see the 'fluidity' of the needle movement on this you-tube video. The video walks thru the Calibration Procedure. For a 5 to 50 MPH gauge, Cal points are sampled starting at 10 MPH, upward every 5 MPH, the last point at 45 (Full Scale minus 5 MPH). The result is an accurate speed report across the full 50 MPH.
http://youtu.be/SwXAfIttEQM
-WNF
Post Options Post Options   Thanks (0) Thanks(0)   Quote cphase Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 9:44pm
Thanks,
Jeff
82 SN
Arch Linux
winniskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote winniskier Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2017 at 8:16am
I am considering a speedometer conversion to GPS as I am too cheap to jump all the way to a Perfect Pass.
Please send current thoughts about an Nautic Logic upgrade.
I prefer an internal GPS receiver. Nautic Logic claims that the internal and external receivers have the same excellent reception. Do you agree?
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2017 at 9:19am
You lose the Nautique face on the internal receiver- it comes with a generic one (presumably pre-calibrated). I and several others have run the external receiver version for a while, they work great. Smooth, reliable and great customer service from NauticLaugic. I added a 2nd one this winter.
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2017 at 10:19am
If you ski I couldn't imagine not having Perfect Pass. I was hesitant for the longest time until I started skiing other boats with PP/ZO.
1976 Ski Nautique 351 Escort
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2017 at 12:25pm
I need some input. One of the limitations I am running into for the Airguide retrofit is the total sweep of the needle motor is 315 degrees.
On a 3 to 50 mph dial, like most of you have, the needle has to do one of two things.
1. To reach 50mph the needle comes to rest at 5 mph.
2. If the needle settles at the post or 3 mph it will not quite reach 50 mph, the needle will top out at 47 or 48 mph.
How big of a deal is this? I know if I were calibrating for myself I would let the needle set at the post. I have never had a boat that would actually go 50 mph! Does yours?
The gps will actually read up to 200 mph. The limitation is the scale not being over 315 degrees. It appears that finding a motor that will cover a broader range of degrees is problematical
but I am not certain about this.
In YOUR opinion is this a problem that should be resolved before further development?
Thank you for your input,
Dean
My take is that there's nobody concerned with speeds below 10, but there are quite a few boat owners who travel just below or very close to 50 (my SS will hit 48). I'd rather be able to read high end then hit the post on the low end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2017 at 12:34pm
This thread is 3 years old, not a relevant discussion as the product is already out there.
If you need to read the upper 40's and higher with accuracy, you can go to a 60mph, 80mph or a custom face with a custom scale if you want... the GPS gauge can be calibrated to any scale you'd like. I am running a custom 80mph scale on my BFN... reads accurately into the 60's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2017 at 12:39pm
This thread is 3 years old, not a relevant discussion as the product is already out there. .
Yes, let's just forget about all the new members who have come on since the old post!
