Transmission Question |
racingnc
Senior Member Joined: July-14-2010 Location: Mooresville NC Status: Offline Points: 170 |
Posted: May-29-2017 at 6:57pm |
I'm sure this has been covered here somewhere on the forum but I must ask again. A little insight first. I have 1986 correct craft ski martinque and about 2 years ago my bilgde pump quit working while the boat was in the water. I drained the trans and added fluid ran it for a few minutes then drained it again I did that about 5 times before taking out. This weekend I took it out for the first time and the trans slipped. It's to the point where I think I might have to get another one or get it rebuilt. I talked to my local dealer and they want to send it off and won't be done for a few months. Does anyone know anyone who rebuilds them close to the Charlotte area?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
I guess an easy question to ask would be
Is it full, roughly 1.8 to 2 quarts ? I see you asked this question last August too about rebuilders, (and got no answers) I don't know any in NC but I'm sure somebody will chime in. At least this time you have one response though I imagine it slips on takeoff since that's when the load is the highest. How many times has it slipped, is it every time you take off? How much run time since the slipping issues Brace yourself cause some guy named Pete will come along and grill you on what kind of ATF you used |
Matt,
PM Ken so you can make arrangements to sent it to him for a rebuild. |
response time 4 minutes Pete not bad
racingnc
You are correct it slips under load and I could not hey past 1300 rpm before it slipped. It is at the line on the stick. I put just under 2 quarts into it this week before taking it out. Not sure what to do thanks for the response.
Looking at old posts, I see that you had synthetic i it for a short time a few years ago, replaced it with normal Dex 3 or whatever, then got water in it later and did a lot of flushing.
It probably won't help but I'd idle it around for an hour or so and get the fluid warm, shifting it frequently in and out of gear and going into reverse too. Give them clutches some exercise. You have nothing to lose by doing this except maybe an hour of your time, Make sure your paddle works or have somebody with another boat tagging along just in case. Then try taking off again Does it slip in reverse too? How many times has it slipped on you? On another thought, have you ever heard the noise a bad damper plate makes,? A slipping transmission makes a racket and so does a damper plate with the springs going bad. To me the damper plate makes more metallic grinding type noises and the clutches slipping are a loud groan. |
racingnc
It doesn't slip in reverse luckily I think. I it did not make any new or unusual noises. It felt like it jumped out of gear. I guess that's why I say it's slipping.
If it did the same thing in reverse there would have been a good chance it was the damper plate.
Cheaper and easier, but no such luck I guess |
racingnc
Guess I need to just ship it out somewhere or spend the money to get a rebuilt one. Just not sure what is the best option at this point.. Frustrating
Duane in Indy
Well your forum nickname does not explain if you are a racing fan or racer that is mechanically inclined.. If you are the latter then maybe you could beat the labor costs by doing it yourself. I just rebuilt mine and it's not as hard as you think. If you don't know one end of a screw driver from the other then I would farm it out.
Kit will run about $150.00. Takes about 3 hours. There are still service manuals available along with pictorial manuals on line. Mastercraft forum has a good pictorial on rebuilding one. We just posted the site a week or so ago. And don't let anyone kid you, KENO is more than capable of doing it but he as well as alot of the rest of us, has already got a full plate. Good luck and keep us posted.. A picture of the tranny plate would be helpful. |
1978 Mustang (modified) |
racingnc
I used to do both drive and build race cars. I never got into auto transmission due the the fact I can't stand the smell of burnt trans fluid. I'll get a pic of the plate tomorrow and post it. Thanks for any and all help. This by far is one of the most generous forums I have posted on.
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3359 |
If you have that background, i believe you can do this.
First put a pressure gauge on the test port, and check line pressure. That will tell you if you have to replace the pump or not. Then source snap ring/seals/front seal /oring kit, new reverse and forward plates, and i used a shim kit to get the forward pack stack height in spec. My belleville washer had a good groove cut in it from the worn forward pack, so i needed one of those too. A good set of snap ring pliers and a nice clean bench, i think you you got this. Take notes and pictures, use the shop manual from this site's reference section. |
shierh
I never touched one of these and am not a pro but I rebuilt mine and its perfect. have 50 hours on my rebuild. So yes its pretty easy,
Only thing is that when you take apart the oil pump, make sure you mark the surfact with a sharpie so you know which way to put the gear back. There are wear marks on both sides of it that should be ok but they need to go back the same way. |
Taking the thing apart in a plastic mortar mixing tub from the home center, collected the fluid and caught small parts, and eventually its broken down and cleaned up , remove the tub and oil and stank, then just working with the bare unit and assemblies on a clean bench.
