Casting plug replacement trick |
ceruzziracing
Newbie Joined: July-07-2017 Location: Kansas Status: Offline Points: 14 |
Posted: July-19-2017 at 6:52am |
I had been scratching my head trying to figure a way to get to the four casting plugs behind the engine mounts w/o having to pull/lift motor. Finally came up with a solution that worked for me on my '97 176. Photo may be hard to decipher but this is what I did. Prepped the openings per usual with sandpaper and ran film of Permatex around inner edge. Placed new plug in block and, using an old plug and small pry bar, pressed the new plug in using engine mount for leverage. Had the old plug with concave surface facing block and levered new plug into seat. Takes some trial and error, and would be great to have smaller hands lol.
Great tip!
Where there s a will, there's a way. |
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3359 |
Tenacity is a virtue, well done
However, wedge a smartly cut 2/4 under the exhaust manifold to take the pressure off, one can take the mount right off. |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6127 |
Does this work for freeze plugs, too?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
Don't worry Larry, Pete will come along with the answer
Ken, I trust Larry's intelligence to be able to figure this one out by himself. He certainly doesn't need me to confuse the issue! |
WinterTurtle
Groupie Joined: July-18-2017 Location: Summerfield, NC Status: Offline Points: 79 |
Good to know it's possible! I have a 10+ year old dry rubber stopper I need to replace with one behind the starter. No idea how accessible (or not) it is but surely an adventure!
Good answer Pete |
Dreaming
just pull the starter... its two bolts and a couple of nuts for the wires. Pulling the starter will save you an hour of futzing to get the two plugs to line up correctly so you can lever the plug in using something you shouldn't pry on |
ceruzziracing
Or in the case of that one, you could utilize a proper casting plug insertion tool. That way you don't lever against anything and concern anyone.... They run about $75 online
Maybe unhook battery 1st, then pull starter. I bet someone has done that backwards & had a few sparks!
