  New Posts New Posts RSS Feed - Quick Fuel float adjustments
1994nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1994nautique Quote  Post ReplyReply Direct Link To This Post Topic: Quick Fuel float adjustments
    Posted: July-22-2017 at 1:46pm
So I have finished doing the protec to carb swap and I have been trying to work the bugs out. I had the floats adjusted to spec with the boat on the trailer. We took it out and ran the boat and the carb started flooding out the engine with gas actually dripping straight into the intake with the throttle in neutral. So I figured I was getting to much fuel pressure so I adjusted the floats down so I could barely see the fuel in the sight glass. I added a fuel filter right before the fuel pump and took the boat out and it ran decent, it acted like it wasn't getting enough fuel, So I adjusted floats back up and ran good, still not the greatest at wide open throttle out of the hole. If I eased into the throttle it would take off better, no sputtering. I adjusted the secondary's so they kick in about 35 mph.
This morning I took it out and it was hesitating at about 30 mph. Did a couple hole shots and it seemed flat, didn't run anything like it did the last time I was out. I checked the float levels and the secondary bowl was good, the primary was to high again and the gas was running into the intake again with the throttle at idle. So I adjusted the float down and it started running good again. I went skiing and it ran good other than it seemed like it was flooding out when it started up... had to open up the throttle in neutral to get it to start.
This is getting long winded and I'm sorry about that but I am running out of ideas on why I can't keep the floats adjusted properly. Any ideas are greatly appreciated! Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2017 at 2:04pm
I am having the same issue of fuel dumping in at idle. I have adjusted the bowls several times. Hope I finally have it dialed in. I called quick fuel and the fella I had advising me knew less than I did and that ain't much!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2017 at 3:50pm
If you have a piece or pieces of junk just upstream of the needle and seat randomly getting stuck in between them and bouncing around it'll drive you crazy trying to adjust the float level as the piece moves around..
I'd pull the bowls and look and make sure the fuel inlet and your fuel line from the pump don't have junk anywhere.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2017 at 4:15pm
Quick fuel is great with warranty if you end up needing a replacement.
Good luck. I've always had excellent luck with the float level adjustments. We had to warranty one because of accelerator pump underperformance but that's all.
Currently messing with Mars' carb. I believe the back butterflies are open too far letting in too much fuel from the transition circuits causing a bad rich idle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1994nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2017 at 4:56pm
That's about where I am, I've messed with carbs a bit but never really fine tuned one. I've never had issues with setting the floats.
I was kinda leaning towards taking the bowl off and checking,
Thanks Guys!
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2017 at 5:21pm
Zach,   You must be speaking about when QFT owned QFT.   Now that Holley has purchased them customer service is not what it was. Still a great product but normal Holley service dept.
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2017 at 5:31pm
Ahh. It was 2 years ago when I dealt with warranty. I returned it to summit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2017 at 7:31pm
Believe Holley purchased QF ~5 yrs ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2017 at 9:46pm
1994 SNOB with a new QF M-600. One morning it started running super rich. Couldn't get the engine to idle. Ran fine at wide open throttle, but idle was 1,500 rpm or engine would die. I pulled the flame arresor off and saw fuel running into the mains. Back at the hacienda, I pulled the float bowl off and found that a small piece of brass had become lodged in between the needle and seat. This prevented the needle/seat assembly from stopping the fuel flow into the bowl -- hence the fuel running into the mains. So, I put in a new needle and seat assembly in the carb and it has performed flawlessly since.
The piece of brass looked like a small remnant left over from the machining process. I don't know where the brass came from, but I'm guessing from the fuel tank as I had recently replaced some of the brass fittings there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2017 at 12:23am
Last year is what they told me
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2017 at 1:50pm
+1
Same story I got from QF / Holley when I called to get recommendations for secondary jets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2017 at 3:25pm
+1
JQ I checked with my dentist and he said to do a Google search and you'd probably find that in 2012 (that's what 5 years ago?) QF was bought by the holding company that bought Holley after some bankruptcy problems Holley had. Everything changed hands a couple of times and now there is Holley Performance Products Group that owns quite a few aftermarket companies and QF is one of them
Holley history (a long and winding road) link
Some QFT historyQFT
So High Performance Industries who at the time owned Holley bought them in 2012
Then everybody changed hands again once or twice after that. That's probably part of the story
So in the end I said to myself"who cares when it happened? or how many times it happened. Just one big incestuous aftermarket industry where everybody keeps getting bought and sold by investment groups
Kinda like being married to your cousin or something and then divorced and remarried again
I'm sure this isn't the whole accurate story because it's probably next to impossible to figure out but it sounds like everybody's right ...........sort of
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2017 at 3:38pm
I hope 1994 Nautique is out playing with his carburetor instead of getting distracted by all this
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1994nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2017 at 7:46pm
I took the primary bowl off and found half dozen little tiny metal shards in the bowl. I didn't see anything on the needle and seat. I was hopingI would see something a bit bigger. I guess if it was bigger there would probably be gas dumping out of the overflow. I'm hopefully going to get out this evening and run it again fingers crossed.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1994nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2017 at 2:06am
Well, took the Nautique out and so far so good no flooding. So the only thing at this time is when I hit it full throttle out of the hole it hesitates until about 2600 rpm then it takes off like it should. If I ease into the throttle it takes off no problem. I opened the gap on the plugs to .055 when I installed the dui, I was thinking I would close them to .050 and see how it runs. Any thoughts??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2017 at 9:22pm
One thing I've done with marine carbs is to extend the vent tubes a bit. (raise them).
Boats move up and down much more than most vehicles do. It helps.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2017 at 11:11am
I don't predict the gap to cure that.
tell us..
Whats your initial timing at?
What PV is in the carb?
How did you set the idle mix?
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1994nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2017 at 1:17am
Never had time to change plugs this week.
The power valve is 6.5, the idle was set at one and a quarter out.
When I set the idle screws I had a vacuum gauge hooked up to the carb vacuum port and I didn't have any reading at all. It is running terrible rich at idle. It loads up and starts fouling plugs until I run it at higher rpm. I was going to try 3/4 turn out on the idle for a while and try that.....
Timing is at 10 deg. BTDC
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2017 at 8:57am
My idle screws are turned out between 1/2 and 3/4 turn. They were more than 1-1/4 until I moved them in. That seemed to help on mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2017 at 9:17am
A picture of the vacuum port with the gauge hooked up might be helpful if you say you have no vacuum reading.
Have you verified the secondaries aren't leaking/dripping at idle.
I see you took off the primary bowl but not the secondary. If you have junk in one you have a good chance of having junk in the other
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1994nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2017 at 1:13pm
Turned the idle screws in this morning to 3/4 turn and she ran like a champ! I will try and post a picture with the vacuum gauge, This quick fuel carb has the two ports on the bottom underneath the primary bowl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2017 at 1:50pm
I'd imagine that you're at a fairly high elevation out there in Wyoming and the idle mixture adjustments make sense.
How high are you? elevation wise that is
Good job, hope it keeps running good now
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1994nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2017 at 2:02pm
Reeeeally high ha, at 6 am - the boats running good - and we're ripping up glassed out water
Elevation wise about 4200 ft.
Thanks for the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2017 at 2:21pm
If you hook into the other port right next to the one you're probably hooked into, you should get a vacuum reading at idle.
One is full manifold vacuum and the other that you probably hooked into is the timed spark port that reads above throttle plate vacuum and at idle it'll read about zero.
Hook into the manifold vacuum port and it'll give you the readings you're looking for.
They look like they tap into the same place but they don't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1994nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2017 at 2:28pm
Ok, I will try it, do I need to have anything tied into the port coming of the metering block?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2017 at 2:37pm
Are you running stock jets? I'm in SLC area and I'm running 2 sizes smaller on jets for the altitude. I typically run between 4,400 and 6,200 feet elevation in Utah. FWIW, She runs like a scolded dog...
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2017 at 2:38pm
That port off the metering block is also a "timed vacuum port" sensing above throttle plate vacuum so you don't need anything hooked to it.
I'd just cover it with a small cap.
I'd probably also take JQ's advice on jets for your altitude.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1994nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2017 at 1:26am
Sounds good, I will keep it plugged.
I will definitely be changing jets at some point, I've been fallowing JQ's posts with the protec swap.
JQ did you change both the primary and secondary jets sizes?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2017 at 1:44am
Yes, I changed jet sizes. I went with the rule-of-thumb of 1 jet size for each 2,000 feet of elevation. As such, I decreased jet sizes by 2 for primary and secondary metering blocks. One nice feature on the QF is that the secondary metering block has changeable jets. The 4160 does not.
Since the jets are fairly inexpensive, I bought jets for one, two and three sizes smaller. The carb also has changeable air bleeds, but I kept those at the stock setting.
Most of my boating/skiing is at Utah Lake (4,400 feet elevation) so the 2X size reduction is spot-on. Out of the box, the accelerator pump was OK and the idle air mixture screw setting was also good. I have not had to adjust choke or vacuum secondaries.
Where in WY are you? What is your elevation?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1994nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 1:29am
I am in the northeast corner, by Devils Tower, about 4200 feet.
Where did you buy your jets from?
