Two thermostats? |
swilliams
Senior Member Joined: June-26-2016 Location: Cincinnati,Ohio Status: Offline Points: 236 |
Posted: August-20-2017 at 3:46pm |
Doing a bit of maintenance and had a slight leak at a hose clamp on the engine water pump(no big deal). Pull off the hose and found that in the thermostat housing there are two t-stats. Now I know that this engine only is supposed to have only one. It's location is in the upper portion of the housing held in by an o ring. This second t-stat is mounted at the base of the housing which you would find in a typical intake manifold to thermostat application. Why would someone do this? I have been running a bit hot(about 180). I think I'll remove it and change the correct one while I'm in there. Motor is the original Omc 350,260 hp. Any thoughts? Thanks,Steve
1976 Martinique,350 Omc. 1975 Glastron/Carlson CV16,115 Merc.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
Why do people do a lot of things?
I'll answer that , bcause they don't know what they're doing or they're too smart to read a manual I'd figure somebody before you was having issues, popped the housing off of the manifold and their question was "why don't I have a thermostat in here?" So using his automotive know how he put one in there and never knew the marine thermostat housing had it in a different spot and ended up with 2 thermostats. That's my guess |
swilliams
Yeah there's a bunch of em out there.Changed t-stat out and ran it on the fake a lake.Gets to about 170 and the manifolds are cool. Not lake conditions but so far I'm ok with it. Next weekend!
