New to me 78 Tique |
Page <1 7891011 21> |
If they are the aluminum and not the stainless commanders, you are correct that galvanic corrosion between dissimilar metals is a problem. It will be between the bolts and the manifolds so that's the area of concern. Get a box wrench on the bolts but if they don't want to come out easily, I'd stop. Getting any penetrating oil all the way past the bolt heads and into the threads will be very difficult so, I'd cut the heads of the bolts off. A die grinder or Dremel with a cut off wheel would be my choice. Then get some penetrating around the holes and get the cold chisel out I mentioned earlier. The elbows should come off and mild heat may help. Now they will be left with the cut off bolts in the manifold. I suggest getting the penetrating (50% ATF and 50% Acetone) out again, stand the manifolds on end and soak around the bolts. I'd keep doing this for several days. Now with a vise grip on the bolts, you should be able to loosen the bolts going both directions. Don't try to remove them completely if they don't come out easy. You want to preserve as much of the threads in the manifolds as possible. Get more 50-50 at the bolts, let it soak in again and try again. Worst case if the threads are bad, thread inserts will need to be installed. The mating surfaces of the manifolds and elbows will need cleaning up and possibly by machining. |
samudj01 ![]() Gold Member ![]() ![]() Joined: March-10-2009 Location: NC Status: Offline Points: 968 |
These are studs with nuts between the elbow and the manifold. Do you think the studs are removable or will the elbow just pop off?
They don't look like studs with nuts in the posted picture but, if they are I feel you are lucky.
Get some 50-50 on the nuts, back them off and then 50-50 around the studs. Get the cold chisel between the elbow and manifold. and see what happens. The chance of the mating surfaces needing a clean up are high so then the studs will need to come out. |
Yes, we were able to loosen all 4 nuts on each manifold. They won't come off bc the length of the stud.
scootdogydog ![]() Senior Member ![]() ![]() Joined: November-03-2013 Location: Central MA Status: Offline Points: 404 |
I couldn't get the nuts off the studs either. You need to cut the studs to get them off. Then get the riser off, then maybe weld nuts to the leftover stud to free them from the manifold
Yes and the reason I mentioned just backing the nuts off.
HM's are very similar but with their riser design it gives you a place to apply a rubber or dead blow hammer. Maybe you can do something like that. Once it starts coming off then you can start backing off the nuts again, you getting them started without breaking off is half the battle
I don't see any risers.
The decision was made tonight that a stringer job will be on the docket this winter. First up keep dismantling the boat and pull the engine. Going to reread as many stringer threads as I can. Wish us luck. We are confident on everything but time. That is our most valuable resource with the boat an hr away and both having young families. But here goes. Stay tuned.
On the exhaust logs...is ours repairable, just glass the end? Are logs needed? Why not rubber tube for long term? We don't understand the fiberglass logs? Is there no lifting point on the 302? We don't see one so we plan to use lifting straps at the four brackets. We will lift with the forks of a tractor so weight and height shouldn't be an issue. Will plan on documenting and probably asking one or 1000 more questions. Now back to reading stringer threads. |
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 10795 |
The logs are those things that are made of some kind of metal that people have been disagreeing about
![]() The fiberglass things that are cracked are mufflers. You can fiberglass them to fix the broken spots or substitute metal or use rubber hose all the way from the exhaust manifolds(logs) to the thru hull outlets. |
By the time you get your stringer job done and are ready for the mufflers, repairing them will be apiece of cake.. You will be an epoxy pro. ![]() |
1978 Mustang (modified) |
No Duane, they will be so good with the epoxy and glass they will be able to make completely new mufflers! ![]() |
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
Throw the mufflers in the trash and use corrigated hose. Get some zip lock bags and a sharpie, and bag and label every part you remove.
David, there should be unused holes at the ends of each head. pick up a chain and bolts that fit those ends and screw them through the chain links. Pretty Simple. Hang onto those bolts label them for future use. PCM installed nice lifting rings in those same holes.
Glass are mufflers. If you want it loud toss them. If you like it as is fix the broken piece. Pretty simple fix. You'll get realllllly good with fiber glass after this winter. The thing felt surprisingly solid in rough water despite the absence of most of the stringers. |
7/16 - 14 thread |
KenO should be on here shortly with pics of lifting the engine out. He is outside now removing his engine to show you how.
.Use this hole on one head and use another on the back end of the other head. Chain will cross engine diagonally
Yes, it's been several days since we've a hands on "kenhowto"! ![]() |
Commander should have plates to use already bolted on. Likely dangling at 6 o' clock. |
Anyone with 16.5ft stinger drawings? Saw some good ones for an SN in uks thread. Quinner, can you send those that you converted to inches?
Also, looking at the latest promo stringer thread, there is a nice us composites list. Anyone have a list for a 16.5 boat. We are just looking for starting points to start our lists |
I do it Zach and Duane's way.
Maybe those lifting plates disappeared in the last 39 years 7/16-14 bolts screwed into the holes at the end of each head, diagonal orientation back of one head to the front of the other, and take the carburetor, alternator etc off first so you don't accidentally beat them up with the chain. No picture of it getting lifted but here's how it gets used when boating season is over ![]() ![]() ![]() |
Like these: ![]() |
Any picture of the guy with the V8 chainsaw when it kicks & lands on top of him, or more likely both halves of him?
Crazy Australians. Go to the website shown on the bar of the saw and you'll find some you tube videos of it in action ![]() |
MechGaT ![]() Senior Member ![]() ![]() Joined: March-09-2015 Location: Chattanooga Status: Offline Points: 271 |
That is a Tim the Toolman chainsaw... more power!
'92 Sport Nautique
Got some good time in on the Tique this weekend, ~4 hrs on Sat evening and ~5 hrs today. Thanks to Greg for coming Sat with some extra beer to help us pull the engine. This project will take a lot of beer. I think Jesse will ring in with some questions as we had a list, but in the meantime, here are a few pics. Basically all parts are off the boat except for the running gear. Hoping to start measuring and cutting out floor, foam and stringers next time which will be Nov 9th.
Can this throttle cable be used. The plastic sheathing broke but it still works fine. Obligatory alignment photo. Of course it was out of alignment. Stay tuned. |
Replace all the cables. Well worth the $200. Looks like your shaft is fretting. It's a nice boat, well worth the effort.
That was the fun part. Looks like you have a nice shop to work in.
'92 Sport Nautique
fanofccfan ![]() Platinum Member ![]() ![]() Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1746 |
Nice shop! and boat!
Do all the cables. The Steering cable felt really nice though. Inspect and if it looks great I would say re use that. Those silver gear/throttle cables are original.
Good work, you are really getting somewhere. Also, take a good look at all of the wiring in the bilge/stringer area. It's seen 40+ years of neglect likely so now is the easiest time to replace/tidy it up. Also, while you are doing glass and wood make sure to replace the transom pads used to screw the platform brackets into. Those are always rotten back there and its a pretty easy job to replace them. Through bolt the platform back in if you don't plan on taking the brackets off the boat on a regular basis. |
