ZDDP Question |
Post Reply | Page 123 4> |
Posted: February-06-2018 at 9:05pm |
The two cams I saw without some of the lobes were out of Hercules/Chris flat heads that in both cases the owner thought he was doing the engine good by going to "modern" oils. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11050 |
That's like ancient times Pete.
Anybody born in the early 50's or earlier is really OLD. You and Gary and Duane and oh yea, me come to mind Can't forget JBear,his brother Bill, Jackie Deen,SNObsessed, a really really old guy named Grant and I'm sure quite a few others that I just can't remember right now Or is it experienced? But anyways, I asked Google and came up with the article in the link. It was printed in 2009. It would suggest 300 ppm or .03% for corrosion back then and then it was jacked up to 800 ppm in the mid 50's for camshaft wear reasons. I figure it's interesting reading and probably won't really change anybody's thoughts that they already have about ZDDP levels and what's needed or not needed. There have been changes like SN rated oils and CJ-4 and CK-4 diesel oils since it was written link |
And rpm's compared to today was low. Good old non detergent oil so all that gunk wasn't circulating around the motor but instead settled to the bottom of the pan
Guessing that the valve springs on that '51 flat head were not high strength!
No scanner so this is the best I could do with the digital camera.
I ran across this Texaco oil ad in 1951 Motor Boating. Interesting they used a CC 42' flying bridge cruiser!! Ken, What do think the ZDDP levers were back then? Note, Texaco hadn't even come out with their Havoline oil yet!! |
63 Skier
I'm on my 4th cam already, and I've changed fluids regularly.
Hi Duane Here's a thread from 10 years ago with some people who had camshaft failures for various different reasons that they blamed on oil. Was it really the oil's fault? .I figure oil has changed some but not much has changed in the last 10 years as far as discussions go and in the next 10 the same discussions will continue. . old thread I guess some people will think the sky is falling and some will figure it's a mighty small percentage that had problems |
Duane in Indy
Think you are confused about what product you are talking about. The study tested a different product than what I had posted. I have no factual information about where the Lucas product rates. BTW I can't recall reading where a CCF person has experienced a camshaft failure due to oil related issues. Pete you are right: it's a cold hard winter |
1978 Mustang (modified) |
curiouslibra
Newbie Joined: January-10-2018 Location: Dallas Texas Status: Offline Points: 26 |
Oops sorry I missed the link. I was just more concerned with the poster that said he used Lucas ZDDP additive to bring up his ZDDP levels but the test show that it did more harm than good and since I didn’t see anybody tell him to go look at the chart I assumed no one had already posted that here sorry.
W
i l l "Don't argue with idiots, onlookers will not be able to tell the difference between the two of you, as the idiot drags you down to their level and beats you with experience." |
rosconole
Gold Member Joined: May-10-2008 Location: United States Status: Offline Points: 759 |
Alot of those private label oils that thread listed are total garbage I wouldn't use them on a mountain bike chain. .
It could all be a ploy to sell oil too...lots of snake and alligator oil. However a wear test is really a better indicator, zinc is really for break in oils typically , probably in marvel mystery oil , zmax, too. Some of the marine oils were actually made or spec'd for certain inboard i/o manufactures for example Mercury wanted a 25-w40 , |
I figure that before you post what you think is some groundbreaking earth shattering news you should read the whole thread here on CCF and you'll find the same link you just posted. Look at a post by phatsat67 on Nov 8th of last year ZDDP/zinc/phosphorus levels fall pretty easily into that category of "things that there's no firm answer to" |
curiouslibra
just when I thought this thread was starting to slow down, I found this test that was very eye opening on ZDDP levels and how they are not the only factor in protecting your engine.
I also post this link because they also test ZDDP additives and none of them helped! in fact they reduced the protect and sometimes by a big percent! http://www.sccoa.com/forums/showthread.php?136304-What-oil-brands-offer-the-best-protection-***Good-read*** |
W
rosconole
I guess I need another boat for a litmus test, 2 is not enough!
Jeeze Ken, now I guess we'll need to start even more ZDDP oil threads!! One for old school off road high ZDDP oils and another for new school EPA approved catalytic converter protecting low ZDDP oils!! |
If you guys are gonna disagree with Roscoe, could you at least get your info straight.
You talk about motor oil with no ZDDP................all MOTOR OIL has ZDDP in it. Some have more than others The newer passenger car motor oils have 700 to 850 ppm zinc and the generally accepted magic number is around 1100 to 1200 ppm for older flat tappet engines. I figure, to each his own, if Roscoe wants to run a lower zinc oil he can take his chances, it's his engine I'm still trying to figure out why the Jeep Cherokee I had that fell apart around the engine was still running just fine with 250,000 plus miles on low ZDDP/zinc oil of around 800 ppm. No camshaft /lifter issues, just good old salt related rust issues. Here's a link to the PQIA website where you can look at the oils they tested and see zinc and phosphorus levels in both the passenger car oil section and the diesel oil section PQIA |
rosconole
OH NO! I better go order a new ZR409 right now just in case!!!!!!! Anyone got a spare Python motor !!!!???
Ross, Hopefully you haven't gone to a non ZDDP oil!! |
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3734 |
Ross, Pete is correct. If you don't want to use zddp install a roller camshaft and lifters.
Flat tappet cams need zddp for protection against wear. Mark |
Ross, Lots including myself have a different opinion. I have seen first hand the damage done when non ZDDP oils were used on well broken in flat tappet engines. |
rosconole
ZDDP is actually only specd at break in so its a moot point now really. Sure probably a higher number is better with a flat tappet. Would have been nice if they used roller motor instead.
That's not as good.
But I know where to get the decals that increase my HP
Yeah, but we get 2-3% increase in RPM with it! |
For you midwest guys, Menards has VR-1 for 4.99 a quart and a .55 cent rebate til the 27th. Blains Farm and Fleet usually carries it for 4.50 a quart.
63 Skier
I didn't know you can buy Amsoil at Napa? Thought it had to be through a dealer.
I used the Amsoil Diesel & Marine 15-40 in a Suburban diesel that I did a test on with the help of an Amsoil dealer, we did uoa on every change. It's an outstanding oil. |
$9/qt, ouch.
Great price. I pay $90~ for 2.5 gals at NAPA. |
rosconole
I'll stay away from the Lucas I saw them on the questionable list on the independent testing, i never was a proponent of putting in additives to oil BUT I have seen how will the Archoil helps my injectors in powerstroke during startup.
If I go away from the Delo 40, I probably end up using 15w40 marine & diesel amsoil since I can use the same in powerstroke and buy in 5 gallons at a time @ 133 for my dealer price. |
Duane, I'm sure it will continue with more winters in the future! |
Duane in Indy
I'll still use VR=1 and not worry about it.. BUT if your favorite oil does not contain enough zinc then this is an alternative.
Must be a cold hard winter to have beat this thread so long, and to have done it last year also. |
