ZDDP Question |
Post Reply | Page <1 234 |
rosconole
Gold Member Joined: May-10-2008 Location: United States Status: Offline Points: 759 |
I guess I need another boat for a litmus test, 2 is not enough!
curiouslibra
Newbie Joined: January-10-2018 Location: Dallas Texas Status: Offline Points: 26 |
just when I thought this thread was starting to slow down, I found this test that was very eye opening on ZDDP levels and how they are not the only factor in protecting your engine.
I also post this link because they also test ZDDP additives and none of them helped! in fact they reduced the protect and sometimes by a big percent! http://www.sccoa.com/forums/showthread.php?136304-What-oil-brands-offer-the-best-protection-***Good-read*** |
W
i l l "Don't argue with idiots, onlookers will not be able to tell the difference between the two of you, as the idiot drags you down to their level and beats you with experience." |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11050 |
I figure that before you post what you think is some groundbreaking earth shattering news you should read the whole thread here on CCF and you'll find the same link you just posted. Look at a post by phatsat67 on Nov 8th of last year ZDDP/zinc/phosphorus levels fall pretty easily into that category of "things that there's no firm answer to" |
rosconole
Alot of those private label oils that thread listed are total garbage I wouldn't use them on a mountain bike chain. .
It could all be a ploy to sell oil too...lots of snake and alligator oil. However a wear test is really a better indicator, zinc is really for break in oils typically , probably in marvel mystery oil , zmax, too. Some of the marine oils were actually made or spec'd for certain inboard i/o manufactures for example Mercury wanted a 25-w40 , |
curiouslibra
Oops sorry I missed the link. I was just more concerned with the poster that said he used Lucas ZDDP additive to bring up his ZDDP levels but the test show that it did more harm than good and since I didn’t see anybody tell him to go look at the chart I assumed no one had already posted that here sorry.
W
Duane in Indy
Think you are confused about what product you are talking about. The study tested a different product than what I had posted. I have no factual information about where the Lucas product rates. BTW I can't recall reading where a CCF person has experienced a camshaft failure due to oil related issues. Pete you are right: it's a cold hard winter |
1978 Mustang (modified) |
Hi Duane Here's a thread from 10 years ago with some people who had camshaft failures for various different reasons that they blamed on oil. Was it really the oil's fault? .I figure oil has changed some but not much has changed in the last 10 years as far as discussions go and in the next 10 the same discussions will continue. . old thread I guess some people will think the sky is falling and some will figure it's a mighty small percentage that had problems |
63 Skier
I'm on my 4th cam already, and I've changed fluids regularly.
No scanner so this is the best I could do with the digital camera.
I ran across this Texaco oil ad in 1951 Motor Boating. Interesting they used a CC 42' flying bridge cruiser!! Ken, What do think the ZDDP levers were back then? Note, Texaco hadn't even come out with their Havoline oil yet!! |
Guessing that the valve springs on that '51 flat head were not high strength!
And rpm's compared to today was low. Good old non detergent oil so all that gunk wasn't circulating around the motor but instead settled to the bottom of the pan
That's like ancient times Pete.
Anybody born in the early 50's or earlier is really OLD. You and Gary and Duane and oh yea, me come to mind Can't forget JBear,his brother Bill, Jackie Deen,SNObsessed, a really really old guy named Grant and I'm sure quite a few others that I just can't remember right now Or is it experienced? But anyways, I asked Google and came up with the article in the link. It was printed in 2009. It would suggest 300 ppm or .03% for corrosion back then and then it was jacked up to 800 ppm in the mid 50's for camshaft wear reasons. I figure it's interesting reading and probably won't really change anybody's thoughts that they already have about ZDDP levels and what's needed or not needed. There have been changes like SN rated oils and CJ-4 and CK-4 diesel oils since it was written link |
The two cams I saw without some of the lobes were out of Hercules/Chris flat heads that in both cases the owner thought he was doing the engine good by going to "modern" oils. |
