Tranny seal |
connorssons
Posted: June-21-2018 at 6:52pm |
Does anybody off hand know the input shaft seal replacement number on a 72c Velvet Drive
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11093 |
It's the same as a 71C seal PCM part number is R047003 National 470774 Alto 023420 and a bunch of others will cross reference 1.375 ID 2.0662 OD .375 width |
connorssons
Thank you so much for the information especially on the other name brands getting ready to put the big block in my Barefoot and wanted to replace the seal!
Jeff,
Take a close look at the shaft. If it looks bad, you may want to put a speedy sleeve on it. |
connorssons
if its needed pete, where do you get one of those?
Jeff,
An auto parts store Was there a leak when it was running before? |
Duane in Indy
Speedy Sleeves are a great fix for worn shafts, but bear in mind that you will have to cut it off the shaft to remove anymore than the front cover. Just make sure that you don't have to dig any farther than the front cover before you install it.
1978 Mustang (modified) |
Jeff,
Duane is correct that if you need to get into the trans say for rebuilding, the sleeve does need to be cut off but, I don't feel that would be a major obstacle over a rebuild. The removal is due to the shoulder on the sleeve. |
connorssons
it was not leaking, just wanted to stick one in before motor was replaced. hello again Duane, and thank youPete
