  New Posts New Posts RSS Feed - Reverse slips under power
DockDoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Topic: Reverse slips under power
    Posted: August-08-2018 at 12:08pm
Looking at a local boat ('93 sport nautique). Dealer took it for a test run and found that reverse gear activates, but when much throttle is applied it seems to slip. Forward gear works fine.
They rebuilt the transmission, and problem persists. Passes compression test with flying colors.
Is this a common problem? I don't know that I"ll buy this boat anyway but I'm interested in test driving it, but also just curious.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2018 at 12:21pm
Not certain regarding compression test, but line pressure , as well as forward and reverse piston line pressure should be available at a test port
It could also be cavitating like a donkey in reverse. Have you witnessed the shaft fail to spin further above a certain rpm?
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2018 at 1:59pm
I haven't witnessed anything, just talking to the mechanic.
What would cause it to cavitate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2018 at 3:07pm
Some models of props often dont hook up well in reverse, and more throttle just makes more bubbles.   A high-cup prop doesn't work well in reverse at all
River Rat to Mole
