  New Posts New Posts RSS Feed - '79 SN Commander Build
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2018 at 9:32am
Copper pipes with carpet remnants tie wrapped around them front and rear for reducing vibration from hull contact was the setup in 76.
Aaron,
I'd like to add that this was pre muffler.
Off Trail View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Off Trail Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2018 at 10:11am
Right, Just curious as I'm deciding between copper and stainless for my straight pipes.
On the vibration dampening note - what is a good modern material to use for pads under the new straight pipes?   I imagine they can get a little warm on the outside, especially copper?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Off Trail Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2018 at 10:41am
Joe - Didn't realize the trim you were talking about was a rubber strip. I'll go with your recommendation to cut right at the seam. Makes sense now that I see the rubber trim.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2018 at 10:50am
Just get some of the cheap black indoor/outdoor carpet from Home Depot etc. and wrap the pipes like normal. Buy it in bunk size cut if you need to replace the trailer carpet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2018 at 11:14am
The OD of stainless (tubing) will match the ID of the hose at 3”. Copper (pipe) will be larger and will require a wrestling match to get it on. And it’ll be significantly more expensive. Since the tubing/pipe is smaller diameter than the hose it usually didn’t require any wrapping to prevent rubbing. It will sit 1/4” or so off the bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2018 at 11:31am
Originally posted by Off Trail Off Trail wrote:
   Replace muffler with 3" copper or stainless. Are either readily available used/cheap, or am I likely buying new tube cut to length? .
Aaron,
There are plenty of on line stores to shop for metals but one thing to consider is stainless VS: copper. The typical copper (plumbing) you find may be sized by the I.D. so 3" will have an O.D. of 3.125" and that makes it harder to get the exhaust hose on. Stainless tube will be sized by the O.D. and then the wall thickness.. So, a 3" tube (.065" wall is plenty) will fit nicely on the exhaust hose. Some will say 400 series (muffler grade) is adequate for corrosion protection but I recommend using 304.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Off Trail Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2018 at 3:05pm
Couple more ??'s:
1) Do the valve covers have gaskets?
2) Never got a response on this one - do I need to retain the carb spacer?   Someone commented that I may have motor box clearance issues with the new intake, plates, and factory spacer all used. Is there a performance reason that I need to keep the spacer in there?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2018 at 3:30pm
You'll have valve cover gaskets if you buy them.
I was gonna mention a day or two ago that you should have bought a complete Felpro marine gasket set and saved some trouble but you already bought stuff and asked questions later[
Go back to my post on 10/12 @902am and the link there talks about the spacer.
It's not needed but the plate is
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2018 at 3:52pm
A couple of other things
You really should buy one of the books that are available on rebuilding small block Fords.
Plenty of good info even if you're not doing a complete rebuild. Usually around 25 bucks
And, your stock valve covers may not clear the new roller rockers.but you won't know till you try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Off Trail Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2018 at 2:37pm
Bummer. I was trying not to ask too many questions. I had read about the gasket kit, but forgot about it when I was actually on summitracing buying stuff.
Also - I had read that post you linked, but glossed over the comment that - 'removing the plate does not affect mixture'. Good to know, plate will go in a box with the mufflers.....as soon as I figure out how to get this damn floor up.   P.O. had new carpet run right over the old carpet, and up into the sides behind the ski shelves. Because there are 2 layers of carpet, I can't find the seam to cut. I'm going to tear it all out when I'm ready to park the boat for good. 42 degrees and sunny today, so I think I'll have to take it out for a shakedown ride.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Off Trail Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2018 at 12:03am
This is a carryover from the other thread I had going about exhaust, but I'm going to consolidate all my issues/question/comments in this thread.
So I finally got a look at the prop and it is an Acme 542. The P.O. must have spent some time on CCFan or got some good advice elsewhere.   So....I don't need to buy a prop at least.
Question - if all goes well and I'm gaining 15-20% horsepower with the heads, rockers, intake - will I need to prop 'up'? Or will the increase in HP just increase RPM's, and I'll settle in at 5,000 RPM and get my best top end. Wishful thinking or likely scenario? As I mentioned before, I'm currently getting 40 mph (unloaded, 2 pax) at 4,500 rpm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Off Trail Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2018 at 12:12am
Someone will probably post the link that I should have found, but I swear I searched....
So that sticker on the side of my engine says 94 Octane. I guess I missed the era when you could buy 94 Octane.   What does everyone run in these 351's?
I can buy ethanol free 91 Octane, which is what I run in my other boat and all small engines. I can also buy 88 Octane non-E.   Being at high elevation I know I am safer running lower octane and can get a little performance bump doing so. Is it worth playing with the 88 Octane or am I asking for trouble?   I'm assuming these engines don't have a knock sensor like the Malibu does?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2018 at 12:44am
You missed the era when gas was rated by the research method and 94 was regular gas
The sticker was printed in 79 and gas was rated by the research method back then
Nowadays it's R+M/2 to get the octane rating.
R+M/2 is always lower than the old research method
You know what works for you at 8200 ft in the other boat, I'd go with that assuming that's what you're using now
And your lack of knock sensor assumption is right
Post Options Post Options   Thanks (0) Thanks(0)   Quote Off Trail Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2018 at 2:38am
Got a nice warm day, so had to get her out for a spin before I start taking things apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Off Trail Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2018 at 2:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Off Trail Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2019 at 2:37pm
Finally started on the dirty work. I pulled 'newer' carpet that had been laid right over the original, and then peeled up the back half of the original carpet.
I was hoping to stop at the seam near the pylon for now. For this winter I want to focus on the structural and mechanical, and make sure I have a good-running, solid boat before I spend the time and energy pulling the whole interior apart. So, plan would be to clean out the bilge hull thoroughly without pulling any more floor, then do the heads/intake/exhaust/new carb, put some removable/temporary carpet in the back for one summer and call it good.
Long term I would like to redo the floor covering throughout, which will require redoing the side carpet, all the way into the bow, etc.
I took some pictures of the progress and was hoping someone that has more experience with stringers, floor work etc. could tell me if they see any red flags, surprises, etc. in the photos. Everywhere I can touch and see them the stringers seem solid. The scupper holes through the stringers have a very small amount of mush (quarter-sized) at the bottom, but the sides and top of the hole feel like dry solid wood. That's good, right??
I'm assuming there is still foam hiding under the outer glass floor, outside the secondary stringer? In my long-term plan I will cut up the outer glass floor and clean out whatever is under it - but I'd rather save that for next winter. Any thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Off Trail Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2019 at 2:38pm
Basically hoping you guys can call out anything that doesn't look original (like the chunk of treated 2"x16" between the stringers), looks like it needs attention, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2019 at 3:26pm
Aaron,
It sure looks like the PO has been doing some work in the bilge. Yes, that 2x isn't original and nether are the furring strips on top of and on the sides of the stringers. What's the removable panel aft of the engine look like? Beyond a visual, what have you done to check the condition of the stringers? Here's a link to Tim's video on checking stringers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Off Trail Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2019 at 9:48pm
The removable panel is 1/2" plywood and is in good shape. The pink/tan carpet (maybe not original) was glued to that plywood, as well as the glass floor on the sides.
I have not inspected the stringers that thoroughly to be honest. Basically looking, pushing on, tapping anywhere I could reach.   I will read that thread and look a little more closely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2019 at 10:03pm
Looks like significant structural work has been done to that boat... all sorts of unoriginal going on (and yes Carpet definitely is on that list).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Off Trail Quote  Post ReplyReply Direct Link To This Post Posted: January-22-2019 at 12:17am
Thanks guys.
TRBenj - Can you pick out anything more specific or would you need better photos? Wondering if you see any signs of fiberglass work, or if it looks more like stuff added outside of the glass?
By tap-test the main stringers seem solid, thought I haven't made it all the way under the gas tank.
