  New Posts New Posts RSS Feed - 5.5 year old battery
Post Options Post Options   Thanks (0) Thanks(0)   Quote rebel skier Quote  Post ReplyReply Direct Link To This Post Topic: 5.5 year old battery
    Posted: March-13-2019 at 7:02pm
I pulled my 85 SN2001 home to get her ready for the River Ruckus.
My Kirkland Costo battery has a born on date of 8/13. Walmart showed that they have the EverStart Maxx 65 in stock, so I headed that way. Carried my Costco battery all the way in and they had none in stock. Now they show none anywhere in the Nashville area.
Wanting to fire up the boat, I put my 5.5 year old costco battery in and the boat roared to life.
Would you all just keep rolling with the old battery? I know it has to die sometime, but it shows full charge on my VOM, and fired up a winterized boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 7:05pm
That's not a good indicator of condition. Run a load test on the battery. FYI, I have the original 9 year old battery in the lezmobile and it's been going through a pretty cold winter (plenty of -20's) without a problem.
EDIT: What voltage did you read and are you sure it just wasn't a surface charge? .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 7:18pm
*lesbomobile
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 7:21pm
Meh keep running it. They usually give you warning.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote rebel skier Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 7:23pm
14.2 (analogue, not digital) resting -- no draw.
To load test, so I just measure at the terminals while firing up the boat, or take it to Napa and let them load test it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 7:30pm
Surface charge is removed by letting the battery sit for 6 to 12 hours.
Have the load test done with a load tester that can apply the specific (1/2 CCA) amps on the battery. Cranking the engine in the boat doesn't do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 7:37pm
*lesbomobile
Kevin,
Make up your mind on the spelling!
Minus ever having a lesmobile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 7:40pm
It goes both ways?
Be honest, did you edit me?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rebel skier Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 7:56pm
I hit the battery with my VOM over the winter, off charge, probably 10-15 times. I feel like the batter was between 13 and 14 (analogue) every time.
I will find a place to load test it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 9:04pm
It goes both ways?
I did not. I had a feeling you had spelled it differently so I did a search.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 9:19pm
So which do you prefer?
*btw the battery sounds like it's functioning perfectly fine
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 9:37pm
Your day to day lesbianmobile is 60 years old?
Sorry that you missed the point I was making.
No, the lesbianmobile isn't 60 years old!
Look at this from an old thread,(not another Mustang restoration thread page 48) you guys both agreed on the name and it was neither of the ones you're talking about.
This must be the more proper full name in the quote
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 9:42pm
General consensus seems to be AUTOZONE for tech stuff.
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 9:49pm
Pete must have lashed out at some [potential] customers at the HD today. He's being overly tolerant on here today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2019 at 11:15pm
Ha, kind reminds me of:
“Ouiser, you sound almost chipper. What happened today - you run over a small child or somethin'?”
rosconole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosconole Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2019 at 1:07am
60+ months , depends on what the battery costco battery was it can't be far from you needing a paddle. Sure you can get a few starts out of it then you put a James Brown tape on the radio for too long and have have a few cold snacks next think you know click click click.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2019 at 8:10am
Last time I checked you couldn't push start a boat. The journey to the Dora show is a 25 mile trip and you're in the middle of nowhere for most of it so I don't think I'd risk it. If ya don't then at least make sure you've got a set of jumper cables on board. Plenty of walmarts along the way to pick up a new one if ya go that route.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rebel skier Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2019 at 6:48pm
The autozone load testing was mixed. They hooked it up, said it was fully changed, but failed the load test. The did it a second time and said it was good. They one more time and they said I need to buy a new battery.
I said thanks and left. I am stalking Walmarts for one in stock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosconole Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2019 at 7:21pm
If you have sam's club , I have heard good things about the Duracell Marine one they stock I have been tempted to try one.
