  New Posts New Posts RSS Feed - Hose question.
Hose question.
Mpost View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpost Quote  Post ReplyReply Direct Link To This Post Topic: Hose question.
    Posted: September-24-2019 at 11:01am
My 98 GT40 used to have a heater installed. Previous owner disconnected it and I don't plan to use it either. My question is there is a hose running from a T with a temp sender down to the block drain hole on the side of the engine. Can this hose be disconnected and the T plugged or removed ant eh sender just mounted in the elbow feeding the T. I want to install the drain valves discussed in an earlier thread this week. Its a pain dealing with this hose when draining the block.
Thanks for any help you can provide.
T
Block drain
84 SN Sold   98 SN    Lund Pro V   1975 Alumacraft
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2019 at 11:11am
Yup, you can plug the holes. The tee can be removed entirely and the temp sender returned to the intake manifold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2019 at 11:18am
Whaaaaat, Minnesota and you don't want the heater. Heck I used mine this past weekend to warm my feet and my daughter was wrapped in a towel with the hose feed underneath.
Best option available.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2019 at 11:52am
Yeah, heater is the best.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpost Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2019 at 3:16pm
Were tough up here! don't need no stinking heater
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpost Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2019 at 3:19pm
Thanks
Thought so just wanted to be sure.
