  New Posts New Posts RSS Feed - injectors Ford F1TE-D5A (substitution)
chicagozalewski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chicagozalewski Quote  Post ReplyReply Direct Link To This Post Topic: injectors Ford F1TE-D5A (substitution)
    Posted: December-03-2012 at 3:46pm
2001 SAN210, 351W GT40 MPI 310HP
Which injectors are compatible (substitution) of injectors Ford F1TE-D5A?
Each Ford 24lb will be good?
The ebay i found a set of Denso, look identical have different sign.
Maybe someone has 2-3 injectors used efficiently Ford F1TE-D5A ?
Thank you for your help.
phatsat67 View Drop Down
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2012 at 4:33pm
I believe they were used in the fuel injected truck 460 applications.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chicagozalewski Quote  Post ReplyReply Direct Link To This Post Posted: December-04-2012 at 9:49am
Fuel Injector, OEM Numbers
0280150913      BOSCH
0280150947      BOSCH
CM4721              MOTORCRAFT
CM-4721      MOTORCRAFT
F1TED1A      FORD
F1TED5A      FORD
F1TZ9F593C      FORD
F1TZC              FORD
anyone applied there any other?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: December-04-2012 at 4:44pm
Did you happen to buy the saltwater basket case SSN out of brewerton NY that was on ebay? If so.. injectors may be the least of your worries.
If it were me I would have no problem buying a set of ebay 24lb injectors that state they work with a 5.0 mustang. If they look the same and are 24lb then they should get it done, but I haven't done it yet so no guarantees.
jhersey29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2014 at 6:52pm
0280150913      BOSCH
0280150947      BOSCH
CM4721              MOTORCRAFT
CM-4721      MOTORCRAFT
F1TED1A      FORD
F1TED5A      FORD
F1TZ9F593C      FORD
F1TZC              FORD
FORD F1TE9F593D5A
Post Options Post Options   Thanks (1) Thanks(1)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2014 at 7:20pm
Might have to use
397-M-9593-LU24A injector and 397-M-14464-A8 adapter now. Putting this up for others as I dug through websites today trying to figure out what is current.
C_Heath View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 3:15pm
Digging up an old thread. Gonna just go ahead and pick up a set of injectors for my 2000 PCM GT40. Gary and Keno have been instumental on helping me with my maintenance. Anyone know for sure now what injectors I need? the F1TE-D5A looks unavailable now.
1979 Calipso Runabout (the boat that got it all started)
1988 Mastercraft ProStar 190 (sold)
2000 Pro Air Nautique/GT40
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 3:17pm
Look for Ford 24# injectors like these- link you'll need adapters too I'll look them up
Here those are EV1 to EV6 is what you need. Just google them and price shop both the injectors and adapters seem to have prices all over the place.
Are you thinking yours are bad? They can be sent out and serviced but sometimes you'll get one or two that are bad and then you might have to source them if the guy cleaning them does not have them
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 3:30pm
Even tho they are a different shape? Those you linked me to look taller? Also, Ill look for the adapters even tho I wished I could find some plug and plays but with a 20 year old boat I may have to step out of my comfort zone a little more lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 3:32pm
Based on my long cranks after warm, I think one of them may be leaky. A pressure test will be done first but just trying to find some in case I need to get them on the way. Thanks again Gary.
Post Options Post Options   Thanks (1) Thanks(1)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 3:37pm
The purple with the adapter fits fine. The ones in my older link have been great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 3:42pm
awesome thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 3:48pm
thanks you guys!
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 4:02pm
Yea you'll be good,they really are pretty much plug and play. They may look taller since they so thin compared to the originals. The adapters are needed since the wiring connection has changed,easier to make an adapter than a new harness.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 4:16pm
awesome!
Post Options Post Options   Thanks (1) Thanks(1)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 12:10pm
I would have been concerned about the harness wires being long enough with the adapter as they don't give you a lot of slack but from the picture they reach, tight but reach.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 2:46pm
me2 but since I saw the pic of jherseys, ill give it a shot
slmskrs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slmskrs Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2020 at 4:19pm
C_Heath, did you order the injectors and adapters from the links above that Gary S provided?  I'm ready to order some, and wanted to check.
Thanks,
Gordon
Gordon '97 Ski Nautique, GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote slmskrs Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2020 at 12:35am
BTW, I've never removed/replaced injectors before.  Anyone have a step-by-step or a good video?  Other than making sure the pressure is bled down to zero, anything else I need to know?    Tools, etc.?
