  New Posts New Posts RSS Feed - Fuel Pump
Fuel Pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2020 at 1:45pm
Ken have you confirmed that the replacement GM pump can be clocked? That seems to be the implication, just confirming.
Like you mentioned, the outlet (hard line) is really the only concerning piece... the orientation of the inlet (soft hose) should be relatively inconsequential.
Yes, it can be clocked
You take out the 6 screws and rotate the valve section and lower housing together and screw it back together.
You can go 60 degrees at a time, some old ones had 12 holes in the fuel pump body, so you could go 30 degrees at a time but the newer foreign made ones like this only have 6 holes.
So in this case he could only have the outlet at the 7 o'clock or 5 o'clock position but not the original pumps 6 o'clock position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2020 at 1:49pm
Correct so, a 30 degree difference should not be a big problem like Ken is all worked up about. Also per that picture he posted, it looks like he plumbs everything with rubber hose anyway so clocking isn't needed.
Your thong must be riding up your crack a little more than usual this morning Pete
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2020 at 3:17pm
There is USCG approved rubber fuel line (assuming that the advert is true...)
LINK to USCG rubber fuel line
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2020 at 9:05pm
Here's a top view of the 89 fuel pump with 12 holes, 6 of them filled by machine screws and the others just look like a black hole.
That's what allows the 30 degree clocking with the old one
By the way...............anybody that wants to can ignore the USCG legal hose fitting, it's fine with me
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2020 at 9:14pm
So ..........back to our regularly scheduled programming, for hdfooter you can order the pump and like has been mentioned by more than one person the inlet won't line up but it's an easy fix with a little hose if you don't have a long enough piece already.
Then on the outlet you can leave it as is or clock things, either way it won't line up like the original..
And then it's your choice of how you adapt the pump outlet to the carburetor.
You maybe can bend your existing line enough, make a new metal line or use USCG approved rubber hose and fittings. It makes no difference to me
You also might shop around a little and you might find a Carter M60502 for around 65 bucks or so
hdfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hdfooter Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2020 at 9:29pm
Thank you all. Appreciate all the help and direction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hdfooter Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2020 at 10:25pm
KENO - Boom, $58. Thanks for the shop around advise!
