Help! Cooling issue! Novice |
Post Reply | Page <123 |
Atomic Dam
Groupie Joined: May-20-2020 Location: Texas Status: Offline Points: 89 |
Yes, I am aware that there was more than one gasket. I was diligent in my repair, thank you for mentioning it though. I have been known to miss things from time to time.
I got her all pieced back together and took her out last night to see if that did the trick, and most importantly to make sure that there were no other issues caused by the overheating. I ran it for about three hours from Idle to full throttle, with no issues. the Temp gauge would creep up to 180 and immediately drop back down to 160 in it's ebb and flow. Which is good, I was able to confirm the thermostat was working well. Water pump sealed off good, no leaks. (I used Fel-Pro KARROPAK Tan Fiber Sheet 1/64" Paper gasket for coolant connections) I did get more water in the bilge than expected, upon further investigation, my starboard side exhaust tube's hose clamp had failed, and I had some water leaking out. Outside of that, I am back in business. Thanks again for everyone's help. I really appreciate all the wisdom received. |
OEF/OIF US Army Combat Veteran '75 Southwind 20 Escort 351W |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
Nothing else to say but
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3359 |
Outstanding. Another happy customer
