  New Posts New Posts RSS Feed - Trailer Question
Trailer Question
jterr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Topic: Trailer Question
    Posted: June-21-2020 at 10:44pm
Trying to build the prop brace that some trailers had and don't have one to look at. See pic and asking should the bottom of brace be at the 6" or 8" from ground??
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2020 at 1:59pm
Went with the 6".
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2020 at 2:04pm
That’s about the same clearance my trailer has. I welded some steel rollers on the bottom cross member so that the prop cage didn’t simply drag on the ground when going over dips, gutters, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2020 at 2:05pm
John,
There are other trailers that are a lot lower than the 6". You made a good choice. Still plenty of clearance at the prop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2020 at 10:23pm
Thought I would post a few pics of trailer work.
Welded and painted, still have to run a brace to next bracket in front with some skids
Redid Fender as boat had been hitting
Tongue
My thought of a tie down with a safety chain
PO did this not sure what went there??
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2020 at 11:49am
Great to see CorrectCraftFan.com back upThumbs Up
Few pics of almost finished trailer repair
Post Options Post Options   Thanks (1) Thanks(1)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2020 at 1:54pm
nice work
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2020 at 2:26pm
John,
You've been busy. Looking great! Clap
