  New Posts New Posts RSS Feed - Riser Leak
Riser Leak
RedSmith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedSmith Quote  Post ReplyReply Direct Link To This Post Topic: Riser Leak
    Posted: August-08-2020 at 8:47am
'88 Correctcraft.  One riser is leaking from the bottom along the seam.  Ideas on whether to replace of try to weld up the cast iron?  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2020 at 9:31am
Arther,
The "seam"? How about posting a picture. The gasket between the manifold and riser is a pretty common problem. Pull the riser and see if it is just the gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedSmith Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2020 at 9:49am
It's the manifold, not the riser, my mistake.  I am going to pull the manifold and have the leak welded up.  Is there a gasket between the manifold and the engine.  I want to get ahead of time.  thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2020 at 10:04am
CC used a couple engines in 88 in different models. Which one do you have? The big or small block?
Did the manifold crack due to not being drained for cold weather? Understand there's the exhaust and cooling water cavities so, I suggest pressure testing after welding to make sure the cooling cavity isn't cracked as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedSmith Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2020 at 10:07am
351 Ford with 4 barrel carb.  Guess it's the big block
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedSmith Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2020 at 10:11am
How is the pressure testing done?  Is this something I have to get done at my dealer or is there a way I can do it?  I do not expect that the crack is due to freezing.  I am very careful in the winterizing, although it's certainly possible.  Thanks for the quick reply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2020 at 10:16am
Pressure testing is done by removing the riser, making a block off plate for the top of the manifold where the riser was, adding water to the cooling cavity and then some regulated compressed air. About 10 psi will show water in the exhaust cavity if there's a crack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2020 at 10:20am
Hysteria View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hysteria Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2020 at 10:27am
Welding cast iron is pretty hit or miss, for the sake of reliability you may want to replace the manifold rather than trying to patch it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2020 at 10:32am
Yes for the unqualfied I agree.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedSmith Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2020 at 10:56am
thanks a lot for the info and advice.  Think we'll try welding and testing first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedSmith Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2020 at 10:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2020 at 10:59am
Doesn’t matter if qualified or unqualified when manifolds are readily available just put that time and effort and money into a new one. Different story if you have something unobtainable imho
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2020 at 1:40pm
I've had poor luck welding cast iron.  I'm with Gary...put your time and ca$h into a new manifold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2020 at 2:41pm
Have you been pre heating the parts over 500F?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2020 at 8:52pm
The manifold's gasket surface is probably pitted.  You can machine it down to get past the pits & it should work.  If they aren't deep you could even file it if you are good at keeping it flat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2020 at 11:36pm
I couldn't get the engine block into the oven...Wink
We did try to pre-heat with a propane torch, but the end results were still poor.  I'm a very average welder.  I need to keep my day job and let the good welders make arcs with cast iron.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2020 at 8:41am
Cast iron needs to be preheated until it is glowing red.
Then stick weld with high-nickel rod.
Post heat for slow cooling.
It would then need to be machined flat again.
Much easier to buy a new one!
