1953 Aqua Skier Restoration |
Page <12 |
ultrarunner ![]() Platinum Member ![]() ![]() Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1867 |
As it should be!
mamaa39 ![]() Newbie ![]() Joined: September-08-2020 Location: Florida Status: Offline Points: 13 |
Thanks for the info. Guess I’ll change the title of my thread
It's the Aqua Skier. An Atom of that era would be 14' 6".
Chief450 ![]() Newbie ![]() Joined: October-04-2020 Location: Florida Status: Offline Points: 7 |
We are not positive it is an Atom skier now that you mention it. We do not have any paperwork on it other than the title. The title has it listed as 15’ 10” long.
NCH20SKIER ![]() Grand Poobah ![]() ![]() Joined: December-16-2004 Location: United States Status: Offline Points: 2214 |
Another good representation of an atom is at:
'88 BFN |
I'm surprised with the Gray 6 cylinder. How long is the boat? are you sure it's an Atom Skier and not an Aqua Skier? EDIT: Looking at the picture again, It sure looks like an Aqua Skier due to the wide deck at the bulkhead between the fore and aft cockpits.
Here's a link to my Atom in the diaries. Regretably all the pictures are lost after the CCfan ransomware hack.
67 ski nat ![]() Platinum Member ![]() Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1199 |
Yes welcome super cool boat to have join us here
You’ve got the master helping you now (8122) I’m thinking the motor is easiest part, probably will fire up Good luck and most importantly, enjoy Should be fun to watch your progress |
It ran 12 years ago but the boat sat for a long time due to my father-in-law’s failing health. It turns over manually. We didn’t have a battery so we didn’t try to start it before removing it for the project.
Rick and Sheila, Welcome to CCfan The Atom and yourselves are a great addition to the group.
What's up with the Gary? Does it turn over? How was it running 12 years ago?
This is Sheila’s husband Rick. I just joined the group. It’s a Gray Marine. It’s a Gray Marine and it ran 12 years ago. My son removed it and all interior parts without trying to turn it over. We haven’t done anything with the motor yet. We have been waiting for it to cool off before we started the project. I have a feeling with a little Maintenance and TLC we can get it running
2 classics side by side! If the boat doesn't leak at this time, use it until it's a problem. Like Pete said, it's pretty much a full resto to fix it right.
Sheila,
Regarding rot, there are hidden spots that you can't see from the inside or out so if you do open up the joints, don't be surprised. On my Atom, I found lots on the transom frame, the stem and then the inner and outer keel. Where's the engine and what is it? A Gray Marine? Is it being worked on?
Sheila,
Thanks for the pictures. Here's what is happening to your Atom. Back when CC built their wood hulls they used a talc and oil based bedding compound between all the frame members and hull skins. With age this bedding dries out so the bond between the frame and skin is lost leaving only the screws holding the two together. On my Atom I was able to simply unscrew the hull skins from the frames. Now getting anything to replace the bedding by just pouring in a epoxy or any other liquid is and will be a "hit or miss". Over the years dirt and oil has gotten into the joint plus old dried out bedding compound will inhibit any bond. The joint must be opened up, cleaned and then bonded again. I would recommend 3M 5200 which is a polyuretane adhesive sealant. I would not use a hard epory like Gluvit since wood boats have some flex in their hulls that the 5200 will handle. Hard epoxies used on wood are known to hairline fracture allowing water to get into the joint and then the rot starts/continues.
Sheila,
Yes, pictures are needed. It sounds like there are some major problems if your father-in-law use Gluvit on the hull. Not something I would refer to as a "restoration". My atom went all the way down to the frame, some new frames, all new knee gussests, new inner and outer keel, some new hull skins, new deck new upholstery, engine rebuild, and plenty of paint and varnish. Get those pictures up so we can give you a better idea.
We definitely need some pictures!
Page <12 |
