Engine Cleaner |
jterr ![]() Gold Member ![]() Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
![]() ![]() ![]() ![]() ![]() Posted: December-13-2020 at 1:56pm |
Just opened up motor cover and discovered my Filthy engine. Suggestions on how to clean without messing up stuff
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3009 |
If you cover coil, distributor, alternator, solenoid switch, carburetor, etc. a steam cleaner will shine that bad boy up. A low pressure hot water pressure washer works, but be cautious and don’t get water / soap where it doesn’t belong. After, spray everything down with WD-40.
John,
Next time you post your engine picture, take it from the other side so it doesn't show that Fram oil filter!
+1 K&N Wix Mobil 1 JQ
Fabcon ![]() Gold Member ![]() ![]() Joined: August-27-2012 Location: Buffalo. Mn Status: Offline Points: 554 |
I am sure it a wix he just painted it to match the valve covers
1976 Ski Nautique 351 Escort
1984 Barefoot Nautique (Parting Out) |
I don't remember the filter but I painted it Orange. I have a Painted Wix also Orange when I change the oil. Could be awhile but with both knees shot been having a hard time just getting around boat much less in it...
OldSchoolBlue84 ![]() Gold Member ![]() ![]() Joined: December-02-2012 Location: Valparaiso, IN Status: Offline Points: 814 |
Kostas
1984 Ski Nautique 2001 |
MrMcD ![]() Grand Poobah ![]() ![]() Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3776 |
The past few years I have been using a product called Purple Power, there is another brand with a similar name and both are citrus acid based so mostly bio degradable but both work very well. Spray it on, work it around with a stiff brush and wash it off with water. I have found it it spends much time on your hands you will get a minor skin burn so gloves are a good idea. Any polished aluminum you clean be sure to wash it off as soon as you get the grease lose. I have found if you leave it on polished aluminum it will leave a mark. I have cleaned several engines, transmissions differentials with this stuff. Local parts store sells a gallon for around $20 and it goes a long way.
