New to me 78 Tique |
Page <1 18192021> |
Author | ||||
DVskier ![]() Senior Member ![]() Joined: September-04-2014 Location: Seneca SC Status: Offline Points: 449 |
It was “original” and I believe it was a big mistake going to ethanol based fuels. Fuel lines break down due to the ethanol and rubber gaskets also break down and clog fuel passages. I know you don’t agree.
On both my 54 and 64, fuels pumps have been rebuilt for ethanol. Carbs have been rebuilt for ethanol. Fuels lines are copper with the exception of 12" of flex at the engine and they have been changed as well. Yes, there are steps that need to be taken for ethanol but if they are taken, you should not have a problem. I haven't since ethanol was introduced.
samudj01 ![]() Gold Member ![]() ![]() Joined: March-10-2009 Location: NC Status: Offline Points: 967 |
I actually forget exactly where we ended up...somewhere in the 8-10 degrees
I can check the rpm with our light but there is no doubt the tach is off. I’ll start with cleaning the idle circuit. |
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 10784 |
Shouldn't any talk about octane ratings have some mention of words like Research, or Motor or R+M/2 ? Back when that manual was written, the Research number was what was posted on pumps and today's R+M/2 method didn't exist yet. Comparing numbers from the 60's and 70's to todays numbers is pretty much worthless. Pete, can I take a shot at working on your YH's? ![]() |
Sure, do you have your long johns out yet? The other morning I was down at the boathouse and skim ice had formed in the slips.
Initial is less important than final... check both. Make any timing adjustments before carb adjustments. Do you have an indication that the idle circuit isn’t working properly? How did you have it adjusted prior? |
When we set timing we went through it all. That was when we got the new springs for the distributor. I think timing is fine but can check again. Only reason I asked is a friend thought the exhaust could be timing related.
On the carb, when we rebuilt, I adjusted the idle screws until the rpms were the highest. Now the screws are having little to no affect so I think the idle circuit needs cleaning. The boat has become difficult to start cold in the last month as well. Once warm just turn the key. |
Luckily that search function has a better memory than all of us, here are some numbers from earlier in this thread, right after the new springs ![]()
And that holeshot issue was solved with a Holley 4160 450 cfm carb.
Took one of our #2 trailers to the sandblaster. Fresh paint too. Looking very forward to putting it back together. This is how it sits now...will be a huge upgrade for the Tique. Old Trailer and new trailer below:
All parts (fenders, bow stop, guide poles, etc) sandblasted and painted as well. What size wheels and tires would have been factory for a 70's #2? How about wheel pattern? This one has round holes on one wheel and triangles on the other. This trailer has larger tires (and maybe wheels too) than the one under the 72 Skier. Going to get a matching set for this freshened up trailer.
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
Looks nice. Our '78 had 14" wheels with pointy baby moons. Were you able to get the bend out of the trailer? Always amazes me that someone can jack knife a trailer so hard it does that much damage.
This is a different trailer we acquired. The old one still looks like heck but actually trailers well. Thanks for the info on the wheels
Morfoot ![]() Grand Poobah ![]() ![]() Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5313 |
Yeah that Bend will buff out. If not then you've got a preset alignment bend already built in for those windy days.
This Tique was a 2 owner boat when we got it. Other than questionable graphics and replaced interior, it was very original. The PO painted the baby moons as they were rusty. We threw them out and went with the plain wheel look.
I’ve towed several trailers that tweaked and they ride down the road just fine with no evidence of uneven tire wear even.
72 was right around the time when they went from 12” to 13” on the #2, whether you can fit the latter depends on which fender style you have. Both would have used 4-lug hubs and wheels. 14” wouldn’t have come on the #2 until 76ish and is when they went to 5-lug (those trailers also got 3500lb axles - at least my 78 did). |
My 77 low boy has 14's and 5 lug.
Thanks all. Should have mentioned, all three of our #2 trailers are 4 lug.
Is that inconsistent with what I said? |
I just thought I'd confirm what's on my 77 since you didn't sound very sure with this statement:
Reading comprehenstion not so great perhaps... the only real uncertainty is when and how widespread the transition to 3500lb axles was, as I havent dissected a meaningful number of post-76 #2 trailers. The transition to 5-lug 14’s is much easier to spot from simple inspection and seems to have been done by 76... though I wouldn’t be surprised if some 75’s had them too.
How about the transition from round fenders to the angles fenders? We have both. This first trailer is getting rounded and will prob get 13” to go with the 4 lug axle. It will hold the 78 tique for now but will be for the 72 skier once it is done. The next one we do will be for the tique so I want to get it right in my head. Will prob stay with 4 lug axle since we have them but could go with either fender.
Square fenders also a 76 change. You can’t run original style square fenders on a trailer that had round ones originally, the crossmember doesn’t extend out far enough. I guess you could do the inverse if you wanted to, might look a little weird.
Made a little progress on the trailer. Added bunks and carpet, lights, and switched out wheels from our old trailer to this one as the ones on the old trailer matched (13" with triangles/baby moons). Also took the winch off the old trailer for this one as it had a winch stand already there. Waiting on new round orange and red reflectors and tubing for the bow stop (we do have the cross member (not pictured)) and guide posts. That tubing is expensive
![]() Had to take the guide posts off to staple carpet. Hope it will be even more complete in a week or two.
Looking good Fellas....That is on BA workshop y'all have. I'm extremely jealous of the Man Cave you guys have got to work in. It's like the BBC Part II.
Be aware that with those fenders, the 13” tires will rub from time to time even with brand new springs. If you haven’t replaced springs, expect those tires to rub pretty consistently (they may not last long). Everything will look fine until you get the weight of the boat on it. Your best bet would be swapping to the larger fenders that started showing up in ‘72 (flat round) or going back to 12” wheels and tires.
Not sure where you’re planning to install the reflectors, but there were round amber ones on the forward part of the frame, originally. The angled fender supports actually held lights (amber front and red rear) on the 71+ trailers if I am not mistaken (mine all have them- fairly certain they weren’t added). They make original style running lights for that spot, as well as the original round tails, in case you hadn’t seen them. |
Thanks for the info. Where are those lights sold? Etrailer? I had not found them. I am worried about the tires rubbing. Looks to be plenty of room but once compressed it probably won’t be.
https://www.etrailer.com/Trailer-Lights/Optronics/ST24RB.html
Yes the unloaded trailer at 400lbs or so will certainly fool you into thinking you have plenty of clearance... especially if those springs are old. Might want to replace them if you haven’t either way, ive even stuffed the smaller 12” into the fenders when the springs are really tired. At 50 years old, they may not have much life left in them (I’ve broken more springs than had flat tires or bearing issues combined). You’re not finding replacements locally/quickly, which can be a pain if you’re far from home. |
More progress made on the trailer. Pinstripe applied, reflectors on, tubing added. Basically complete at this point. Planning to order some 12" wheels and tires for it in the coming days. Know it isn't a perfect restoration, but it makes us happy to have a renovated trailer.
Nice!
New 12 x 5.30 tires installed. Basically done (we are planning to move the boat forward a bit more to get better tongue weight). It is a nice upgrade.
Page <1 18192021> |
