  New Posts New Posts RSS Feed - 302 rear main seal
302 rear main seal
Jdavis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jdavis Quote  Post ReplyReply Direct Link To This Post Topic: 302 rear main seal
    Posted: June-11-2021 at 3:20pm
I just recently purchased a 76 ski Tique that the previous owner let the engine freeze and crack the block. I think I have found another block but I am having trouble finding the 2 piece rear main seal for a reverse rotation engine. Any suggestions or help would be greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2021 at 3:53pm
Is this it?  https://www.marineengineparts.com/fel-pro-17746-2-piece-rear-main-seal-ford-302-right-hand-rotation
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2021 at 3:59pm
I question that part number because Summit,O'Reilly's,Jegs,Advance etc all show that it is available but in their description does not list reverse, only marineengineparts state it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2021 at 4:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2021 at 6:11pm
This may be rather silly of me, but the 2 piece rear main seals are smooth and the oil control/wick/helix lines are on the crankshaft so why spend the bucks on a "marine" seal when you can use an automotive 2 piece seal for quite a bit less money?
What year block are you looking at?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2021 at 6:25pm
If you look it up by part number all except eBay are within a few dollars of each other - eBay is 10 - 11 cheaper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2021 at 7:14pm
But if you look up a rear main seal for a 77 ford 302 and come up with a FelPro part number like BS30136 or 2901 for example, it's a bunch cheaper. (edited to add the 2901 seal)
Must be paying for some "marine rubber" Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2021 at 7:35pm
I wonder what the difference between the two is- Felpro is not calling it marine
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2021 at 6:35am
Using Summit prices for consistency
Felpro 17746 labeled "marine" ..........51 dollars
Felpro 30136 not labeled marine...... 18 dollars
Felpro 2901 not labeled marine.........27 dollars
I think you're paying for that word Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jdavis Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2021 at 11:28am
Thanks for all the help. I’m going to dig around a little more and see what I can come up with
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2021 at 11:45am
Must be safe to assume you're looking at a block built sometime before 1983?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jdavis Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2021 at 5:54pm
Yes I am looking for a pre 1983 block
