Pertronix Ignitor/Coil Setup |
Post Reply | Page <123 |
Hysteria
Groupie Joined: May-31-2020 Location: Indiana Status: Offline Points: 70 |
I agree with you, and not knowing the answer is going to bother me until I run the boat with it off again. I went back after installing the 540 and looked at a .gpx file from when I ran the boat in it's original form last year, and it shows a top speed of 40mph. I can't imagine it's slower with the new prop, and the only variable that comes to mind is the FAE. I backyard engineered it of course, and ended up with a lot of spray coming through my swim platform that I had to address afterwards. I'm sure it's adding a lot of drag and screwing things up under the water.
Like you suggested, the solution is pretty simple. I know I need to run it without the FAE, it's just hard to bring myself to take it off because it's so nice having it on there. |
Hysteria
This is the part in question. If anyone has a suggestion on how to improve it, I'm all ears. I tried to imitate the other FAE I had seen online, but ended up with a lot of water coming through the platform and had to put some foam under the slots to stop it.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11059 |
Hey, is that your first CCF picture? Congrats
Looks well built and a good copy of what's out there. I can barely spell FAE and know nothing worthwhile about them other than they're quiet and keep the nasty stuff underwater, but it's seems like it would be pretty deep in the water, adding extra drag, unless it's just the camera angle. That one picture will make the "noisy boys" start clutching their chests and mumbling something about having the big one, but it's your boat so you can do whatever you please
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1774 |
I’m a noisy boy……your pipe looks well built but I would think it could be much shorter and still be effective for noise reduction and not produce so much drag if in fact it is.
Hysteria
I've posted a few on here, but man it's tough to make them work on my phone. This site in general is pretty bad on mobile, but it's worth it for the information.
I'm pretty much over loud cars/boats by now, but I built it after reading what the CO can do to people who ride behind the boat or in the back seat. Anyway, I can probably take a few inches off it like you guys suggested and still send the exhaust well past the tub.... I mean slalom skiers. |
Hysteria
I cut around 4-5 inches off my FAE and gained some top end, so I think you guys were right on the money there. Didn't seem to make any difference in noise levels either, which is great.
Now that the boat is running well, I'm looking at installing the Edelbrock performer intake I picked up for the boat last winter. Are you guys blocking the exhaust crossover when you install an aluminum intake, or leaving the system intact? I'm also looking at a set of gt40p heads that a local guy is selling and was wondering if there is anything I need to watch out for on the swap other than drilling it out to 0.500" for the 351 head bolts and installing brass freeze plugs? From what I'm reading, it looks like a pretty straightforward swap that can reuse pretty much everything but the spark plugs. |
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2957 |
FWIW I blocked the passage at the head when I installed the Performer RPM unit in the ‘94. No issues.
Some “P” heads come pre-drilled T 1/2”. You will like the 90 degree spark plug holes when it comes to changing plugs. When changing heads, valve train geometry is critical. Lots of instructional videos on YouTube for all that stuff. If you are changing heads, are you thinking to go with roller rockers?
I think I'd drill them (gt40P) to the same size as your present 351 heads and that's 17/32 Here's some reading in the link below |
Hysteria
No, I wasn't planning on switching to roller rockers. Mostly because I'm assuming there would be some pretty significant cost involved and I'm not sure if the boat is really worth that kind of an investment in it's current form.
Thank you for the tip on drilling them to 17/32". If they need to be opened up anyway and that's what a 351 head is from the factory, I don't see any reason not to. |
If it's the Performer 2181 manifold that you have, you should read the link below for info on a spacer plate that'll keep you from having vacuum leak issues due to the skinny mounting surface for the carburetor on the manifold. |
Hysteria
Thanks again KENO. I noticed that mounting surface was pretty thin when I was cleaning it up (it's a used intake) and was wondering how well it would seal. That plate looks like a great idea
