  New Posts New Posts RSS Feed - Wiring diagram 1982 Ski Nautique 351 Ford
morris2125 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morris2125 Quote  Post ReplyReply Direct Link To This Post Topic: Wiring diagram 1982 Ski Nautique 351 Ford
    Posted: August-15-2021 at 3:17pm
 Hello
I have a 1982 Ski Nautique with the 351 Ford.
I have an aftermarket alternator that has four wires. I am looking for a wiring diagram please.
Any help would be greatly appreciated.
Thanks Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2021 at 3:50pm
Matt,
This may help but it only shows 3 wires. I know Ken will be by who can really help. Post what alternator you purchased.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2021 at 5:23pm
Originally posted by 8122pbrainard I know Ken will be by who can really help. Post what alternator you purchased. <div><br></div><div><img src=uploads/1765/PCM_wiring_351_30.jpg height=500 width=554 border=0 /><br></div><div><br></div><div><br></div>[/QUOTE 8122pbrainard I know Ken will be by who can really help. Post what alternator you purchased.
[/QUOTE wrote:
Ken can probably help, but you'll have to answer Pete's question first  Wink
Is this a PCM 351 engine or maybe a Commander 351.<
It would also be good to know what your old alternator was and how many wires it had hooked to it.
An 82 most likely had a Prestolite with an external voltage regulator unless it was replaced at some time in the past. The regulator would be on the back of the engine near the relay/solenoid for the starter and the main breaker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote morris2125 Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2021 at 8:30pm
 This has a Prestolite ignition, 351 PCM Ford  it looks looks a Mando alternator.AC155614 M56750
I got into this project at halftime. I do not have old alt. Probably two of the wires can be combined.
Thanks again, Matt
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2021 at 8:50pm
Thanks again, Matt
Take a look at the Mando pictures in the thread in the link below and see if that helps.
In the picture with short wires hooked to the alternator you'll see the following.
Orange is output terminal
Jumper installed between output and sensing terminal
Black to Ground
Yellow is excitation from 12 volt  source, same power that supplies the ignition  and the choke
Maybe the second half will be good to you Wink
If you have an external regulator as mentioned earlier, it can be removed completely, since this Mando is internally regulated
Post Options Post Options   Thanks (0) Thanks(0)   Quote morris2125 Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2021 at 10:29pm
 Thanks for your help. Tomorrow I will get back at the Nautique.
Matt
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2021 at 6:01am
Not knowing if you had an external voltage regulator or not, you might have to be working from this early PCM wiring diagram for your boat.
The Purple wire with the Purple arrow pointing to it going to the regulator would be used to supply alternator excitation by lengthening it to go up to the alternator.
The stuff circled in Orange isn't needed any more
