  New Posts New Posts RSS Feed - 79 nautique rebuild
79 nautique rebuild
 Post Reply Post Reply Page    <1 101112
Post Options Post Options   Thanks (1) Thanks(1)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2021 at 9:53pm
Don’t sweat it Dan. Nothing a small angle grinder won’t take care of. I’d love to have a welder to learn that. BTW, nice detail routing out to flush-mount the dog house hinges. Can’t wait to get down there to check the beastie out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: December-01-2021 at 9:31am
I've had a grinder in my hands for going on 38 years, never knew they had a safety shield till i bought my first 1.
Never installed and always removed the safety shield, it just doesn't work with it on.
 Used them as a router cutter grinder polisher any where time or place.
They're always trying to twist out of your hand especialy when your just barely holding it for doing surgery then bam !  grooves chunks and burns on the fingers arms knees and legs whatever it gets a hold of.
While grinding the ski boat my 4 inch rattled it self apart (they don't like fiberglass dust)
Out of desperation i used the 7 inch polisher from harbor freight as a grinder, and i't's my plan to never buy or use a 4 inch 12000 rpm grinder ever again.
The slow speed 600 to 3500 polisher torques like mad to give you the rpms selected no matter how hard you lean on it. It doesn't throw dust as far, it routes cuts grinds sands polishes and is sugical X's 10 over and above the 4 inch every day of the week.
You can get 7 inch and  4 inch foam backing pads for velcro discs and they are way less expensive than the  flappy discs.     right now i got 36 thru 1000 grit,  another trick is to hole saw out a beat up pad to 2 inches and cut the centers out of the discs that have been used up along the outside, it's like having a 7, 4 and 2 inch grinder all in one, and for 40 bucks
https://www.harborfreight.com/corded-7-in-10-amp-variable-speed-polishersander-64807.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: December-02-2021 at 2:21pm
not a bad day, got the house cleaned, evergleam up so i guess bringing the
welder into the dining room will have to wait another month.
a buddy gave me the scoop on some skis i picked up the lot for 60 bucks. Keeping the ho and obrien pair with the holy fins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2022 at 7:06pm
Making a true to size transom shaped patio table, it will be gelcoat finish glass and core construction on aluminum legs,
Rubrail across and stainless cupholders for exhaust tips. The masonite is just a template.
I really need a stencil or traced outline of the,    ( CORRECT  CRAFT )
        (  competition ski boat )    signage for the transom
Also making a wider, taller and bolstered seat plug, for a side/ other project
Upholstery has started on the ski boat i'll update after it's finished
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: March-22-2022 at 5:11pm
My buddy did the buckets last week and the rear bench over the weekend, it was just installed today
Post Options Post Options   Thanks (1) Thanks(1)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: March-22-2022 at 7:23pm
Well done WOT. Thx for pics
MechGaT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MechGaT Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2022 at 11:02am
Looks great! Have you had it on the water yet?
'92 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2022 at 12:06pm
Thank you, but all i did was give a 3x5 fiberglass index card sprayed with gel along with non skid and paint pinstripes for him to match the colors.
I love it, in my opinion the color/design choice couldn't have been better,
(my upholstery buddy was more or less given creative carte blanche)
Been in the water a handfull of times, runs great thanks to some guidance, good advice and motivation from the members here on correct craft fan.
80SN Barnfind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 80SN Barnfind Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2022 at 3:54pm
Congrats Wayout! Your skills and diligence really made the project turn out well.  I loved watching the progress in this thread, can't wait to see your next project!
Knowledge comes by taking things apart: analysis. But wisdom comes by putting things together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: March-25-2022 at 9:19am
It really is a head turner. I bet you will get lots of thumbs up at dock.
Please start another project
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: March-25-2022 at 2:49pm
New project ! What's the rush ?
Well, the plug for the first mold of the next project got buffed today, so i guess it has started.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: March-25-2022 at 2:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: March-25-2022 at 5:21pm
Hmmmm.....mystery mold.....hmmmmm
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: March-26-2022 at 8:57am
Sure does shine whatever it is!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2022 at 11:07pm
Sold the ski boat today, absolutely positive it is off to a good home that is now a 2 boat family.
No doubt there will be many great times onboard for years to come
Both parties happy.
Bitter sweet, I only had it in the water 4 times for test/adjust/tune, and not since the last video, what 4 months ago in nov- dec, but i miss it already.
Susan's 78 Tique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Susan's 78 Tique Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2022 at 2:49pm
I just came across your thread -- nice boat! My husband has these ST-360's and LOVES them! He bought them 40 years ago and they're pretty warn out and I can't find any rubber replacements for the broken boots. Any suggestions? Do anyone know of any other's out there?
My '78 Ski Tique Family Boat
Purchased NEW in the summer of '78
Restoring it LIKE NEW for the summer of 2018!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2023 at 9:01pm
Just breezed thru the thread and was reminded of the help and motivation you guys gave me.
Again greatly appreciated.
Next engine and trans go directly to their respective shops for a rebuild.
