  New Posts New Posts RSS Feed - 1982 PCM pcv hose
1982 PCM pcv hose
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Topic: 1982 PCM pcv hose
    Posted: January-05-2022 at 4:05pm
The fitting on the carb spacer and the PCV valve don't match-the PCV valve being smaller. Is there a special hose for this, or just heat/stretch/force? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2022 at 5:45pm
Stretch.  You don’t want air leaks.  Nothing super special about PCV hose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2022 at 6:17pm
Thanks JQ
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2022 at 7:19pm
I think if you measure the fitting on the PCV valve you'll figure out that a 3/8 ID hose is a good fit and if you measure the fitting on the spacer, it's slightly tapered and about 9/16 of an inch.
That's a lot of streeeetching for that poor 3/8 hose.Wink
PCM had a part number for that hose. It's R045050. It comes with different ID ends.
I have no idea if it's still available these days.
I've used a 9/16 ID gas/oil hose that can clamp over the 9/16 fitting on the spacer and then with multiple sizes of heat shrink tubing, built up the fitting on the PCV so the hose slid over it and could be clamped on.
No stretching needed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2022 at 8:11pm
Chances are it's not a PCM part anyway but in fact supplied by Ford. I had the same problem when looking for a replacement hose for my HM. Did my homework and found one here that worked- http://www.cjponyparts.com/catalogsearch/result/?q=289+pcv+hose
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2022 at 8:29pm
Great. Thank you all.
