Flywheel ring gear |
99airwarrior
Senior Member Joined: August-19-2019 Location: Reno Nv. Status: Offline Points: 141 |
Posted: June-16-2023 at 10:58pm |
I purchase a new flywheel ring gear from Nautique parts it has a bevel on it which way does it go on 351w 1985 ? Also was going to change the input seal on my direct drive velvet drive 1to1 ordered the seal 2 years ago went to put it in and its wrong does anyone have the correct number for it . its model number is 10-17-04 Thank You Joe
Holy smokes for what they charged you should call them for info and make them work for it. Are you talking bevel on the teeth? If so they should face the starter
99airwarrior
It has a bevel on the flat section that presses onto the flywheel usually things are pretty easy to figure out, but the old one is flat on the side going into the flywheel .
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11116 |
Not the best picture of the bevel, but the beveled side goes on first. It just makes it a little easier getting the gear aligned and started on the flywheel when you're installing it. You can install the gear with either side facing in, since there's no corresponding beveled area on the flywheel itself, just a flat shoulder for the gear to sit against. The original Ford gear probably has no bevel on either side. |
Your other question on the Borg Warner seal........their part number is 10-00-044-014 or sometimes written 1000-044-014.
Google either number and you'll come up with plenty of replacement seals
By the way, just to make you feel not too bad about the 47 dollar nautiqueparts price that you paid and maybe make Gary clutch his chest and think he's having the big one, PCM's part number is R139006 and the price is about 155 bucks You could also buy one from RockAuto for about 20 to 22 bucks depending on the brand 20 and free shipping on Amazon ATP-ZA503 and Pioneer FRG157N are a couple of examples |
99airwarrior
Thank You Everyone for all the help Joe
99airwarrior
Love the Fred Sanford, one of my favorite and Aunt Ester
